6637 question?
Old Aug 19, 2011 | 08:17 PM
BluePitt's Avatar
BluePitt
6637 question?
Does anyone know how to get the filter lower / behind the battery more. I am having trouble with this little issue. Plus its right up on the hood. Thanks guys.
Old Aug 19, 2011 | 08:22 PM
snakedoc's Avatar
snakedoc
i just removed the air battery box and it fits good. if you leave the box in you have to cut the box to make it fit.
Old Aug 19, 2011 | 08:28 PM
Sheldon Plankton's Avatar
Sheldon Plankton
It's a real tight fit on the 4" inlet tube. Try applying a little grease to the tube and you'll be able to slip the filter on as far as you need to. Loosen all the clamps and you should be able to position the thing just about anywhere you want. Then re-tighten the clamps, of course.
And if you haven't already done so, you'll have to cut the factory battery box.
Old Aug 19, 2011 | 08:29 PM
BluePitt's Avatar
BluePitt
I did cut the box. But it is a squeeze between the battery box and that wire harness . Right now I'm afraid to shut the hood hard cause its right up on.
Old Aug 19, 2011 | 08:32 PM
BluePitt's Avatar
BluePitt
I cut the corner by the insulated pipe. It seems like I can get more clearance if the stock filter box tabs weren't in the way.
Old Aug 19, 2011 | 08:44 PM
BluePitt's Avatar
BluePitt
I guess I'm going to take to take a sawzal to those tabs for more clearance.
Old Aug 19, 2011 | 08:49 PM
Franko72's Avatar
Franko72
Molon Labe
It should just tuck under the fender lip.
I cut away the complete battery box till just the tray was left.
Pay no attention to the dirty filter cover....
pugster
6.4L Power Stroke Diesel
May 21, 2014 01:37 PM
Rose Clifford
Jul 26, 2011 10:32 AM
wadesmith
Jan 18, 2008 11:11 PM
fdaugher
Mar 27, 2006 02:57 AM
Steve_250
Apr 14, 2005 03:16 PM
