Couple Pics and a question
Old Aug 18, 2011 | 10:58 PM
Lloydable's Avatar
Lloydable
Hey Ya'll, I haven't been on in a while, been super busy this summer. Lot's of time in the mountains and lots of lake time.
Anyway, Today, the truck started taking extra cranks to start, it started with one, and toward the evening, now were at 5 to 8 cranks to start, and it sounds like it doesn't want to, and all the lights including the headlights flicker a lot more than normal... simple answer... batteries.
So I ran over to the auto store before they closed, and we tested each battery separately, and together. He said they checked out fine, and had a good "surface charge".... meaning the alternator is good?
My fuel filter is clean, and only has about 5000 miles on it, oil is 6000 miles, and air filter is maybe 1000 miles. Truck has 311800 on it. Fuel pressure gauge is normal... I am not sure what a bad starter sounds like.
So, do I ignore the fellow at Oreilley's, and purchase new batteries tomorrow? I have been considering Optimas and have hear mixed reviews. I am pretty hard on the truck during the winter, so the strongest battery i can buy is a plus. Thoughts?
On a side note, some good Ol' 7.3 pics from the Colorado Mountains:
Top of Picayne Pass in the San Juans
Little bit of snow on Imogene Pass, this is in August...
Summit of Imogene Pass
TooHellYouRide, Colorado
Engineer Pass Summit
Lots of Color
Crossing Mirror Lake on Tincup Pass
Old Aug 18, 2011 | 11:01 PM
snakedoc's Avatar
snakedoc
you may have clogged screens in the fuel tank.
like the pics!
Old Aug 18, 2011 | 11:30 PM
Lloydable's Avatar
Lloydable
like the pics!
Interesting, so do the in tank mods, which would be good to do anyway.... but wouldn't i see a drop in fuel pressure, or a loss of power?
Old Aug 18, 2011 | 11:34 PM
73ferdf250highboy's Avatar
73ferdf250highboy
voltage drop test: slap a volt meter on the batts have someone start it. check the voltage drop. i have honestly never done it on my truck-since it starts, but if its something crazy like 10 volts you could be losing a cell or two in one or both.
my 02
kurt
Old Aug 18, 2011 | 11:39 PM
Lloydable's Avatar
Lloydable
my 02
kurt
Will do, another question, I noticed that when the tuner is in 80e (more fuel) it starts easier than in stock... thoughts?
Old Aug 19, 2011 | 12:16 AM
73ferdf250highboy
have you ever changed the oil in your hpop? you have good fuel pressure, i wouldnt know where else to look. im still learing these powerstrokes
i have 2 optima red tops in our daily driver vws' they work great. have run them down pretty low a few times-to needing recharges and they have held up well.
nice pictures
kurt
Old Aug 19, 2011 | 12:22 AM
BigAlsPSD's Avatar
BigAlsPSD
nice pictures
kurt
No need to change it really, it gets circulated through in short order as soon as you start it up.
Old Aug 19, 2011 | 12:24 AM
BigAlsPSD's Avatar
BigAlsPSD
The flickering headlights, seems like it should lean towards a bad alternator to me, or a possible loose connection on the alternator, or a bad ground. Check the condition of the battery cables and terminals, clean those up well too.
Old Aug 19, 2011 | 08:22 AM
roostercrows's Avatar
roostercrows
I had the exact same issues, it seemed like the batteries were going but it turned out to be the starter was done... no cranking power. I would clean and check all your connections first, and go from there.
Old Aug 19, 2011 | 08:28 AM
Brother Les's Avatar
Brother Les
Good suggestion. One of my starter bolts had fallen out and I was loosing ground...
while you are messing with the starter, just take it off and get it tested.
Old Aug 19, 2011 | 08:43 AM
honeydew's Avatar
honeydew
cool pics, is that a marine bimini top in your bed or what?
Old Aug 19, 2011 | 08:45 AM
Cell's's Avatar
Cell's
X2 on the starter . I just had to replace mine because both bolts were looses which caused the Big Power cable to crack the selinoid housing , and finally break it . I was getting a slower and slower crank each time I fired it up .
Old Aug 19, 2011 | 09:23 AM
Rose Clifford's Avatar
Rose Clifford
If you do get batts, just get some wal-marts and ruin them after 1.9999 years and return them for freshys.
saves you $200 or so
Old Aug 19, 2011 | 09:31 AM
Lloydable's Avatar
Lloydable
Alright, I remember that thread about the loose starter bolts, so I will take a look at it.
I recorded a video of the problem last night with a cheater view of voltage, and fuel pressure. I shortened it for just the hardest start. After that, it seems to start better. I haven't tried this morning. You'll need some volume.
Aren't you supposed to be able to see RPM's fluctuate while its cranking? Mine is not showing any movement until it starts.
<iframe width="560" height="345" src="http://www.youtube.com/embed/stUUzaLkDl4" frameborder="0" allowfullscreen></iframe>
Old Aug 19, 2011 | 10:42 AM
BigAlsPSD's Avatar
BigAlsPSD
I get an error,"This video is private" when trying to view...
