'95 351 Roller Motor
Old Aug 19, 2011 | 06:23 PM
14&Ford's Avatar
14&Ford
Well, i have officially jumped off a cliff,
I bought a 95 351 Hyd Roller motor as a core to rebuild and put into my daughters 82 F100.
Has anyone here used this donor motor for a mild street build?
My machine shop says this is a great platform to start with as alot of the basics are there.
Anyone got any resonable HP combos for this engine?
$2000 is the budget NOT including the $300 core, the carb, manifold or exhaust. JUST the long block.
I would LOVE your input!
Thanks, Sean
Old Aug 19, 2011 | 06:48 PM
Old Hickory's Avatar
Old Hickory
If you want to make horsepower with a 351W then you need to improve the breathing
of the engine. This would require very good cylinder heads with 2.02 and 1.60 valves
and a good roller camshaft with good induction and good exhaust. The best deal on
good cylinder heads would be aftermarket Dart, World or RHS cast iron heads. These
can be bought from Summit or Jegs. The induction should be an alumium intake with a
600-650 carb. and you should use long tube headers with free flowing dual exhaust.
The cam doesn,t need to be very wild but have a good broad torque curve. If the
truck happens to have an AOD auto trans then you need to be very careful about
hooking up the TV linkage for the trans. If you don,t have an AOD, then it is very
easy to modify the engine.
Old Aug 19, 2011 | 08:53 PM
14&Ford's Avatar
14&Ford
Im looking to get between 250-300hp in a perfect world.
The trans is an AOD. so any pitfalls you can help me avoid, the better. This is going to be a daily driver with enough grunt that she can take it to the HS drags on the weekends.........
Old Aug 19, 2011 | 10:43 PM
14&Ford's Avatar
14&Ford
Anyone
Ive got a good machine shop doing the build. Any specifics to hit that 275HP mark?
Old Aug 20, 2011 | 03:07 AM
Greyf100's Avatar
Greyf100
Stock rebuild with lightning spec cam and gt40 heads should put you at the 280-290 mark. Thumper e7's and a decent cam should put you over the 300hp mark. The '95 lightning made 290 hp stock, your numbers should be easy to hit.
Just don't go too wild on the cam to keep the hp/tq numbers at a useable RPM for a truck.
Old Aug 20, 2011 | 06:48 AM
Franklin2's Avatar
Franklin2
You whole budget is going to have to be used to beef up the AOD if you are going to drag race with it behind a 351w.
And like someone else said in a earlier post, to make power with a Ford engine the first thing to do is get rid of the factory heads and go with something aftermarket with a adjustable valve train and reasonable flow ratings.
papabills54
Nov 6, 2012 02:11 AM
14&Ford
Aug 21, 2011 12:39 AM
Shade
27
Dec 29, 2008 08:43 AM
stinkfist
Nov 1, 2004 12:35 AM
Critter
22
Mar 2, 2004 07:14 PM
