Help 351w ID
Old Aug 19, 2011 | 12:29 PM
86ford94's Avatar
86ford94
Help 351w ID
Hello everyone this is my first post on this website. I need to know if my engine is a 351w or a 302. I have an 86 f150 (partially, mostly f350) and the original engine was a 302 but the guy I bought the truck off of said he put a 351w in it. Here is the block casting number: e4ae-6015 and then It says fa-19. I know it is an 84 block but don't know how to tell if it is a real 351w.
Old Aug 19, 2011 | 12:57 PM
ctubutis's Avatar
ctubutis
Welcome to FTE.
There is some help for your particular questions here in the Sticky:
Ford Truck Enthusiasts Forums - View Single Post - '80-'86 Tech Tips, Tricks and Projects:
Old Aug 19, 2011 | 03:43 PM
Franklin2's Avatar
Franklin2
Old Aug 19, 2011 | 08:40 PM
hotrodford87's Avatar
hotrodford87
You can also look at the spark plug wires. 302 firing order is 15426378. That means the 2 plugs closest to the firewall on the drivers side will be two spark plug wires right beside each other at the distributor cap ( a common problem with 302's as the 2 cylinders fire one behind the other and it's easy for the plug wires to 'leak' and fire between one another...just fyi). 351 firing order is 18436572 so number 7 & 8 spark plug wires are not one behind the other like a 302.
Old Aug 20, 2011 | 03:09 AM
Greyf100's Avatar
Greyf100
302 HO motors use the 351 firing order.
Non HO 302's use the old 289 firing order.
Old Aug 20, 2011 | 06:45 AM
Franklin2's Avatar
Franklin2
Also aftermarket cams can use either the 302 or 351w firing order, and they both interchange in either engine.
Nyls
Jun 10, 2009 08:28 PM
speedracer54729
Dec 30, 2007 09:12 PM
mulletmaster55
Feb 25, 2005 04:19 PM
huckermatt
Aug 8, 2003 07:24 AM
jimbo81587
Nov 10, 2002 09:25 PM
