1996 E150 tranny question
Old Aug 19, 2011 | 07:43 AM
Geardriven77's Avatar
Geardriven77
What would cause an otherwise proper shifting auto transmission to start shifting hard? I have to run out 1st and accelerate until it finally clunks into 2nd. My first thought was a lack of fluid but that usually causes slipping. Fluid level appears to be full.
Thanks!
Old Aug 19, 2011 | 09:15 AM
ctubutis's Avatar
ctubutis
Moved here from 80-86.
Old Aug 19, 2011 | 09:20 AM
Lazy K's Avatar
Lazy K
What engine and transmission is it?
Old Aug 19, 2011 | 11:35 AM
Geardriven77
Engine is a 4.9L
I think the tranny is a C6 but not sure
Old Aug 19, 2011 | 11:38 AM
Conanski's Avatar
Conanski
In a '96... very unlikely, it's either the E4OD or 4R70w.. both of which are COMPLETELY computer controlled.. so that's where you start by pulling the codes.
Old Aug 19, 2011 | 01:18 PM
Lazy K's Avatar
Lazy K
If it is a C6 it will have 17 pan bolts and your problem would be either the vacuum modulator at the trans is bad or the vacuum pipe to it is disconnected/bad.
Old Aug 19, 2011 | 01:55 PM
ctubutis's Avatar
ctubutis
From Franklin2's diagrams:
Old Aug 19, 2011 | 03:52 PM
Geardriven77
C6 it is.
I found the cause of the problem. Cracked and deteriorated vacuum lines. I replaced them and all is good.
DCFord
13
Feb 1, 2011 05:44 PM
jkarne
2004 - 2008 F150
Jun 11, 2010 08:06 AM
maa139
Oct 25, 2006 03:53 PM
copedipperoh
Jul 12, 2004 05:23 PM
blue93f150
16
Jan 7, 2004 03:35 PM
