Correct tranny fluid ?
Wanted to ask you guys what the CORRECT tranny fluid that should be used for dents. The level is fine in my '79 F100 Ranger, auto tranny, but need to know for future reference. Should Type F be used or Dex/Merc? I also have an '86 F150 XL with auto tranny and I have always used Dex/Merc and all has been fine. Will using one over the other create issues with the tranny in dents? I believe I have the C6 tranny in both my trucks, but not positive.
My 2 cents: I see a lot of guys putting lukas etc. type fluids in their transmissions and I recommend against it. they say that is firms everything up. which is does but thats cause it breaks down slow. With that it amplifies the slippage issues when is breaks down and makes it all worse in the end. Your better off using a synthetic atf. Valvoline makes a product called maxlife for atf and engine oil, its a conventional oil with synthetic property. Good luck and thats my 2 cents.
Josh
I would just use type F.The only difference between Dexron/Mercon and type F is type F has an anti-foaming agent in it. Have you ever heard of B&M trick shift? It's a racing trans fluid that B&M sells and it's blue. It's type F with blue coloring.
When I got into building transmissions back in the late '80's, a very good builder told me this. For the last 20+ years I've been building transmissions, I use type F in them. Ford, Chevy, doesn't matter. The only draw back is it's getting harder to find. The only damage to the transmissions where mechanical failures. (broken cases, shattered planetaries, broken spragues, etc. All the clutches looked like new when we tore them down. These were high horse racing applications we were playing with. I still use type F in my racing transmissions.
This is just my experience, take it how you want to.
jcoleman777
1983 - 2012 Ranger & B-Series
06-11-2013 07:19 AM
TheKirbyMan
09-17-2011 08:39 PM
Billyclub
06-07-2010 08:49 PM
VORTMAX_99
1999 to 2016 Super Duty
05-04-2009 10:19 PM
