no start condition
Old Aug 27, 2011 | 08:50 PM
Snuggyworm's Avatar
Snuggyworm
@ david moore, which part of houston? i'm in houston too. on the west side heading towards katy. do u know the mechanic that u brought ur truck too?
i know lotsa mechanics in this area, and i can tell u if they're straight wif u or not. no offense to ur mechanic.
also, if u need original ford or motorcraft parts, let me know. i got a 25% discount and i believe i can help u out there. i dont charge anything. no catch. jus a fellow diesel owner trying to help out another. i usually shop wif mac hail ford. i also got a buddy at mac haik chevy too. it helps. lol.
jus need part numbers and we can meet and i'll take u to get ur parts, and ur in charge of the bill.....or i'm sure we can arrange something.
call me or email me or pm me. we should talk. have a great weekend!
Old Aug 29, 2011 | 09:42 PM
david moore's Avatar
david moore
@ snuggyworm, tyvm i will get back with you in a few days ,truck will be home tues. night or wens. I need to do a little checking myself on the truck,and many thanks to all that have tossed ideas at me
Old Aug 29, 2011 | 09:54 PM
david moore
Crank is ok (WHEW) bringing her home tue. I am going to tear into the harness myself @ home and see what i can see. anything special i should be looking for other than broken,chafed or burnt ?
Old Aug 30, 2011 | 01:18 PM
Snuggyworm's Avatar
Snuggyworm
pretty much it. crank is ok. good. not the crank sensor then.
can it start? i hope so.
u mentioned u changed out parts from "working model"? used?
i'm sure u miss ur truck. i would too if it was gone so long. i'm sure she'd be sad tat she's away from me tis long, and tat i can't be all over her.
nah, my wife dun miss me. she knows i can take care of myself. its my truck tat misses me. lmao.
best of luck. i'll talk to u soon, dave.
Old Sep 2, 2011 | 11:16 AM
david moore
harness
ok guys heres the question which harness ,5c3z-12b637-aa or 5c3z-12b637-ba ,went to the local ford dealership and found out production date was 11/13/04 and at that date ( 11/04 ) they changed from aa to ab per ford . H ow can i tell the difference ,no tag on harness and its out of the truck now.
Old Sep 2, 2011 | 02:26 PM
david moore
update ba model
Old Sep 4, 2011 | 07:41 PM
Snuggyworm's Avatar
Snuggyworm
the updated one will be fine. if not, return it and get the other.
Old Sep 9, 2011 | 06:34 PM
david moore
new harness
how do you get to the crank sensor ,i have installed the harness except pluging in the crank sensor,still have to fill up anti-freeze and put back belt tensioner ,hookup batteries
Old Sep 9, 2011 | 06:52 PM
BLADE35's Avatar
BLADE35
here it is
looks like a tight one
Old Sep 9, 2011 | 07:00 PM
david moore
tight is right,i can barely see it ,i took the ground lug loose ,it made a little more room but i still cant reach it from the front and theres no way to get to it from the back of the engine cross-member,there has to be a trick to it
Old Sep 9, 2011 | 07:22 PM
m-chan68's Avatar
m-chan68
A 10mm and 13mm swivel head GearWrench will be your best friend for this part of the job. There just isn't an easy way around it. You'll need to unbolt the A/C compressor from the block to gain proper access to it. Given that there are two parts of the harness that clip to the block, one of which is directly behind the compressor, I refuse to install this in any other way, other than the way it came off.
Old Sep 9, 2011 | 07:26 PM
david moore
that was my next move ,i was hoping there was a easy shortcut ,guess some things can only be done one way, lol
Old Sep 9, 2011 | 07:29 PM
  #28
cheezit's Avatar
cheezit
pretty much the easy way right there. it sucks but it is what it is.
Old Sep 10, 2011 | 12:17 PM
  #29
david moore
clackity clackity clackity its ALIVE
Thanks for all the help everyone !!!!
Old Sep 10, 2011 | 12:23 PM
  #30
david moore
running again
H P O P , I P R , EGR DELETE , Engine Harness , and awsome help from all my friends on here , soon to come SCT,
bigtdriver
Sep 27, 2013 10:10 PM
Kels_Bubba
Jun 28, 2013 04:48 AM
NYC F-350
Feb 27, 2011 10:25 PM
vortechf150
May 5, 2006 08:58 PM
