Fog lights.
Old Aug 18, 2011 | 12:18 PM
Mitch1407's Avatar
Mitch1407
Fog lights.
I have the 2000 XLT that didn't come with factory fog lights. My new brush guard has holes for fog lights and I want to make a clean install. Im hoping that I could wire them into the headlight switch because like the trucks with factory fog lights I can pull the switch out ( i just don't know if it will do anything). If anyone has done this mod let me know if it works, if not maybe I can make a new mod
Old Aug 18, 2011 | 12:38 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
I would put the fog lights on a separate switch rather then buy a new head light switch that is used on trucks with fog lights.
Plus this way your fogs will definitely stay on when you hit the high beams.
Here's a schematic by jtharvey for reverse lighting. Just substitute fog for reverse and ignore the factory reverse wire and diode.
Old Aug 18, 2011 | 03:53 PM
Brother Les's Avatar
Brother Les
Robin is correct. With the factory installed fog lights, the switch pulls out to turn them on. But when you switch to 'High Beam', the fog lights go out..... I don't like that very much, I want them to stay ON......
Go with a seperate switch to give you more control.
Old Aug 18, 2011 | 06:48 PM
cj45lc's Avatar
cj45lc
When Marty & I put my fogs on the truck we used the parking lites to trigger the relay. I really like it that way, fog lights are on with high or low beam.
Old Aug 18, 2011 | 08:26 PM
Mitch1407's Avatar
Mitch1407
Thanks fellas! I think Im going to do the separate switch since they will be larger lights than the normal fog lights. Just waiting for the $$
Old Aug 19, 2011 | 08:30 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Or you can install a Brite Box and have lows, highs, and fogs all at the same time. When people flick their high beams at me, I flick mine and the look on their face is priceless. They always look like they're staring into the sun.
Richard_cranium
Apr 1, 2008 08:03 PM
jlmotox
1997 - 2003 F150
Feb 10, 2008 10:10 PM
98infinity
1997 - 2003 F150
May 11, 2007 11:35 AM
skilife17
Electrical Systems/Wiring
Jan 12, 2007 11:31 AM
jesus_man
Nov 12, 2004 09:58 AM
