Rough Idle
Old Aug 18, 2011 | 09:44 PM
cheezit's Avatar
cheezit
pull exhaust ouitlet from back of turbo and inspect for oil in pipe. if so suspect failing turbo.
Old Aug 18, 2011 | 10:18 PM
colbster's Avatar
colbster
No oil in downpipe completly dry
Old Aug 18, 2011 | 11:10 PM
colbster's Avatar
colbster
would it be the injection pump?
Old Aug 18, 2011 | 11:38 PM
brickie's Avatar
brickie
There is no injection pump per say, you need to read this 6.0L Bible Table of Contents
and this https://www.ford-trucks.com/forums/8...rnational.html
Old Aug 19, 2011 | 02:03 AM
bismic's Avatar
bismic
COULD the oil in the exhaust really be coolant mixing w/ soot (it can look like oil, but does not feel like oil at close inspection)?
Old Aug 19, 2011 | 08:33 AM
colbster's Avatar
colbster
Its either coolant or water.
Old Aug 19, 2011 | 03:35 PM
colbster's Avatar
colbster
lame *** ford dealers wanting $140 an hour, someone please helppppp!!!!!
Old Aug 19, 2011 | 05:46 PM
cheezit's Avatar
cheezit
sometimes right cost moeny. hacked and parts tossing cost more...
I have run accross a few 03/04 with a volume supply issue from the pump. look for elavated ipr at hot idle.
could be an injector sticking as well.
both will give you white smoke.
Old Aug 19, 2011 | 05:54 PM
colbster's Avatar
colbster
Consistent white or just at start up
Old Aug 19, 2011 | 06:17 PM
cheezit's Avatar
cheezit
depends on the pump and the truck. but normall a hung injector will smoke white all the time. a low output pump may or may not cause smoke but can in theory cause idle issues.
Old Aug 19, 2011 | 06:36 PM
colbster's Avatar
colbster
It has to be a low output pump than cause It doesn't smoke. Any tips on how to check that? The pump seems to humm a lot and I can't remember it doing it like this before but then again I may just paranoid.
eaglefire21
25
Dec 5, 2016 12:36 PM
YoungFordAddict66
Mar 15, 2011 11:53 AM
sturoe
Apr 29, 2008 04:36 PM
