Rough Idle
Aug 18, 2011 | 09:13 AM
Rough Idle
My truck has developed a rough idle, seems to jump rpm from around 750 to 650 but seems like it may be the lift pump but i have no experience.
And before you says its the programmer it happened before i even installed it.
here is a lil video.
Aug 18, 2011 | 06:30 PM
Can you tell us more about the truck, like maybe what engine you have, what mods, what transmission?
Aug 18, 2011 | 06:59 PM
6.0l diesel, auto tranny, intake manifold and edge programmer
Aug 18, 2011 | 07:07 PM
Aug 18, 2011 | 07:11 PM
Moved to the 6.0L Powerstroke Diesel forum.
Aug 18, 2011 | 08:08 PM
unplug the ebp and see if it goes away.then let us know and someone will tell you what to do from there.
Aug 18, 2011 | 08:14 PM
fixed* i used the search button
so do i just unplug it and start it? if it runs right its plugged up?
Reason: idiot
Aug 18, 2011 | 08:39 PM
unplug it and see if it goes away. if it does then more then likly a vgt issue not an ebp issue.
Aug 18, 2011 | 08:41 PM
Aug 18, 2011 | 08:50 PM
Aug 18, 2011 | 08:54 PM
not sure what ****** is unless its crap your refering too
Aug 18, 2011 | 08:59 PM
exactly
so i unplugged it and started and got the same thing
Aug 18, 2011 | 09:16 PM
ok what is ipr% and icp at 185* and idle. possibly a high pressure oil leak. keep in mind a slight fluctionation in rpm is normal however yours does seem a little higher then that.
also what is icpv koeo?
Aug 18, 2011 | 09:21 PM
sorry how do i find those out?
Aug 18, 2011 | 09:37 PM
Also seems like there is an abundance of extra oil in my exhaust
