Top Speed?
Old May 13, 2018 | 04:44 AM
  #31
Boss9F100's Avatar
Boss9F100
Originally Posted by BarnieTrk
jstephens2,
By changing the rear end gear set to a lower numerically ratio would reduce the engine rpms when at speed. However, by doing so will reduce the gear multiplication (torque) at the rear wheels. If you never tow or haul loads, you may not miss the higher gear ratio.
As OldHarlley indicated, back in the 60s, these old trucks were likely not designed nor INTENDED to be driven much over 70 mph.
Notice the advertisements from the day on these old trucks, most of the talking points were about hauling & towing and a few points about ride quality. I can't say I've seen any ads referencing top speed abilities. Now did these trucks have some sort of governor system or rev limiter? - No. So are they capable of speeds over 70 mph? - sure. But it wasn't a priority when they were built back in the day.
Which brings us to, "How fast can they be driven SAFELY?" BOSS9F100 says he'll soon have his '66 F100 capable to attain 140 mph. I'm confident that he'll have modified the OEM suspension & drivetrain to be driven SAFELY at those speeds. Now some here will claim they've driven their OEM 40+ yr old truck beyond 70/80 mph....some specifying to only try it on a clear, smooth, big road. Such a run would be preferred to be conducted in broad daylight, as the OEM headlights did not provide good vision in the darkness at higher speeds.
If you plan to find the 'top end' of your ol' truck, please first ensure you're confident that the steering and brakes are in the BEST CONDITION THEY CAN BE to allow you the peak control it can afford.
I prefer to drive & enjoy these ol' trucks as they were intended, for hauling and towing and driving under 70mph. When I want to go faster, I will jump into a Mustang or similar 'speed intended' vehicle... JMHO.
BarnieTrk
140+ safely. Yes I have added 14” 6P Brakes all around, added 8L of FE power with EFI, added a custom designed front sway bar along with ZR rated tires and a Gear Vendors Overdrive. My daily driver can cruise all day long @ 75-80 About what one needs to do on local freeways to keep up with traffic.
It runs 35 mph per 1000 rpm. 2800 rpm @ 100 mph.
Old May 14, 2018 | 04:51 PM
  #32
Amish65F100's Avatar
Amish65F100
My 65 has been up to 90mph and still had plenty left to give. I figure I could reach the 120 peg if I wanted to but I prefer to keep it around 70-80mph on the freeway. Not to mention that my 10mpg drops scary low when speeding for too long.
Old May 15, 2018 | 11:32 PM
  #33
mountain dewd's Avatar
mountain dewd
My 66 f250 4x4 with a souped up 300 and 4.56 gears will do 100 all day with no hands on the wheel.
Old May 16, 2018 | 07:59 PM
  #34
The Masked Rider's Avatar
The Masked Rider
O COME ON GUYS. All 3 of mine will do 150+. In fact, I was in my 66 and glanced down at the GPS and it said 165. Than I woke up. I was breathing like a rat on a wheel. WHAT A RIDE........
Old May 18, 2018 | 10:06 AM
  #35
Boss9F100's Avatar
Boss9F100
And then you woke up at bottom of grand canyon realizing it was only a couple thousand feet not all day . .
Old May 18, 2018 | 10:19 AM
  #36
Boss9F100's Avatar
Boss9F100
Not so sure about the others but without question the power is there to do 140 in my '66 Short bed
Truck 1 did 105 quarter @ 13.0 being 4700 lbs effortless to cruise @ 100 mph 1966 F250
Truck 2 current build has a 6 cylinder and should run 11's in the 1/4 mile. Prob never dare try top speed but cruising all day @ 80+ no problem 1966 F250
Truck 3 Short bed should also run 11's in 1/4 no question it should go 140+ 1966 F100
Truck 4 Should run 12's in 1/4 mile and easily cruise 80 mph all day long with a 170 cu in engine. Its a 1966 F100 4x4 and prob get 25 mpg @ 65 mph
Truck 5 being 7000 lb plus should run 130 in quarter mile and its a BBF
Truck 6 is a 3.0 FWD no clue on speed but 80 mph cruise all day no problem.
Old May 18, 2018 | 11:26 AM
  #37
Capjack01's Avatar
Capjack01
"Truck 2 current build has a 6 cylinder and should run 11's in the 1/4 mile. Prob never dare try top speed but cruising all day @ 80+ no problem 1966 F250"
ok, now you've got me super interested in what you've got going with the sixer.
I just grabbed the clifford 2x2 and header setup for my '66 F250. yet to go on, but I have run 11's in the 1/4 and that's bloody fast. taking this behemoth down the track that fast with a 6 has to be quite a setup...one I don't foresee in my future..
mine sitting the way it is....I would need an MX missle crammed up its butt to do 11's
can I ask how?
Old May 18, 2018 | 12:35 PM
  #38
TA455HO's Avatar
TA455HO
Lead Gopher
This thread is hilarious. It went from a guy asking in 2011 if he should be able to do better than 60-65 on the highway. Now we are up to 150 on the racetrack! Lol. Hahaha.
I like it!
Chad
Old May 18, 2018 | 03:21 PM
  #39
1972RedNeck's Avatar
1972RedNeck
can I ask how?
Direct injection, turbocharging, intercooling - it all adds up.
Old May 18, 2018 | 03:23 PM
  #40
Boss9F100's Avatar
Boss9F100
can I ask how?
The key is less weight. This F250 should be I had hoped 3700 lb but thinking it may tip scale closer to 3800. Hoping a couple hair driers or weed blowers will help give boost to the 6. Also going with a 6 spd trans too. Nice to keep it automatic.
The amazing truck will be the F100 4x4 that will run 12's on only 170 cu in. but still get great MPG and SPG
Old May 18, 2018 | 03:26 PM
  #41
Boss9F100's Avatar
Boss9F100
Cool
I like it!
Chad
I only stir the pot as much as needed to keep things from getting burnt . . Ya know, Like 1/2 throttle. The BBF will only have a 3/4 Race cam or just shy of 3/4 to keep it streetable. Like around .703 Lift . .
When one has PPG heavy duty stir sticks one can let 'er rip.
Old May 18, 2018 | 03:34 PM
  #42
Boss9F100's Avatar
Boss9F100
I like it!
Chad
150 mph would be only 5000 RPM. That's doable if one were brave enough to hold er down
Old May 18, 2018 | 03:35 PM
  #43
TA455HO's Avatar
TA455HO
Lead Gopher
My stir sticks are only made of bamboo....
Old May 18, 2018 | 04:02 PM
  #44
Boss9F100's Avatar
Boss9F100
can I ask how?
I had my PPG stir sticks on full STIR.
170 cu in sounded good its actually 164.7641 cu in or 2.7 Liter as from a 2015 EcoBoost F150. It will have the 2.7 tuned to about 390 RWHP and would guess it will be well under 4000 lb. It also has electronic locking axles (3.55's) on front and rear. A Boosted Launch should get it into the 12's. I left out just a "few" pertinent details because I happened to have the PPG Heavy Duty paint stick in my hand.
The other 1966 F250's may be six cylinders but both have 3.5 EcoBoost engines. Current build has the 2017 Ford GT Turbo's on it so should make 480-500 RWHP and 550 lb ft torque. Being 3700-3800 lbs the picture has been "photoshopped" Yeah its only a 6 (six) but when you read the small script .. I was getting bored spending so much time on these trucks had to take a break.
Old Dec 1, 2020 | 12:52 AM
  #45
Vixon Phillips's Avatar
Vixon Phillips
I mean I've have mine up to 125 but if it had any more power the gearing would top it out at about 135
mine in nearly stock but have a 4 barrel intake with an edlebrock carb
