Top Speed?
Old Aug 18, 2011 | 10:44 PM
Rgd9664's Avatar
Rgd9664
post your vin and if your rear end is stock then that could tell you
Old Aug 19, 2011 | 04:45 AM
jowilker's Avatar
jowilker
Originally Posted by jstephens2
I've had my 1966 F100 for about a month now. The top speed I've seen is around 60-65 MPH. I'm not looking to race the thing, but I want to make sure that is normal and nothing is wrong with the truck.
As long as the truck is in gear you pretty much can't blow it up going down the road. You probably can hold the throttle wide open sitting still and do it, but too many things are thrown in to do so while moving.
Take it out on a big road and hold the gas pedal down.
John
Old Nov 23, 2011 | 09:35 PM
forddude66's Avatar
forddude66
sorry, i know this is an older thread but, i was looking for the top speeds and i ended up seeing this. (should have just looked here in the first place). i have a 66 f100 with a 352 3 speed manual, all original and i have been driving it for well over a year and havent gone on the highway yet. i have only had it up to maybe 50 or 55, but my dad has had it up to 75 and he said there was still plenty to go. im just affraid to because the engine has A LOT of miles on it, and it definately doesnt stop on a dime either.
Old Nov 24, 2011 | 04:27 AM
jowilker's Avatar
jowilker
Not gonna hurt it dude. As long as the tires are ok, take it out for a spin on a big road. They would go fast out of the box 40 years ago.
John
Old Nov 24, 2011 | 08:27 AM
BarnieTrk's Avatar
BarnieTrk
jstephens2,
By changing the rear end gear set to a lower numerically ratio would reduce the engine rpms when at speed. However, by doing so will reduce the gear multiplication (torque) at the rear wheels. If you never tow or haul loads, you may not miss the higher gear ratio.
As OldHarlley indicated, back in the 60s, these old trucks were likely not designed nor INTENDED to be driven much over 70 mph.
Notice the advertisements from the day on these old trucks, most of the talking points were about hauling & towing and a few points about ride quality. I can't say I've seen any ads referencing top speed abilities. Now did these trucks have some sort of governor system or rev limiter? - No. So are they capable of speeds over 70 mph? - sure. But it wasn't a priority when they were built back in the day.
Which brings us to, "How fast can they be driven SAFELY?" BOSS9F100 says he'll soon have his '66 F100 capable to attain 140 mph. I'm confident that he'll have modified the OEM suspension & drivetrain to be driven SAFELY at those speeds. Now some here will claim they've driven their OEM 40+ yr old truck beyond 70/80 mph....some specifying to only try it on a clear, smooth, big road. Such a run would be preferred to be conducted in broad daylight, as the OEM headlights did not provide good vision in the darkness at higher speeds.
If you plan to find the 'top end' of your ol' truck, please first ensure you're confident that the steering and brakes are in the BEST CONDITION THEY CAN BE to allow you the peak control it can afford.
I prefer to drive & enjoy these ol' trucks as they were intended, for hauling and towing and driving under 70mph. When I want to go faster, I will jump into a Mustang or similar 'speed intended' vehicle... JMHO.
BarnieTrk
Old Nov 24, 2011 | 09:04 AM
huckdeuceman's Avatar
huckdeuceman
Not stock, 351w with FMX auto trans, cruise all day 75 run up above 100+ just can't
get pass a gas station!...lol
Old Nov 24, 2011 | 08:16 PM
1972RedNeck's Avatar
1972RedNeck
My '66 4X4 with 4.56:1 rears and a 4 speed goes 75. I figure that's about 3700 RPM. It's real smooth at 70.
Old Nov 24, 2011 | 09:54 PM
ras4434's Avatar
ras4434
Don't know for sure what the top speed is. Every time I really get going the speedometer sticks at 100 and from there it is a guess. Not quite to a fruit of the loom moment yet. Guess I could start up the gps and have a passenger watch it.
Old Nov 25, 2011 | 05:16 AM
jowilker's Avatar
jowilker
What a difference the rear ratio can make. With a 3.00 ratio, my tach at 3,000 & the speedo sez 82mph.
That truck prolly came with a 240 6 banger in it.
John
Old Nov 26, 2011 | 12:56 AM
The Masked Rider's Avatar
The Masked Rider
I have to agree with John. I am also running the 3.00 ratio now but I also run the C6 with a 2800-3000 stall speed torque converter. I can light em up all the way down the street and still get great MPG on the highway. I used to run a 2.75 with a 2400 converter but the off-the-line was a little slow so I upped the stall. I'm thinking that now with the higher stall, I might give the 2.75 another try. As for top end speed, well, I forget.
Old May 7, 2016 | 06:08 AM
Jonathan Minnis's Avatar
Jonathan Minnis
they adjusting the throttle body to gas peddle linkage
Try adjusting the linkage from the throttle body to the gas peddle . I had a 65 with the 300 3.9 I6 and before I adjusted the linkage I got her up to aprox 130 but took a great bit to get her to that speed . I'm only guessing the mph based that my speedo went to 90 and I had it touching the 0mph marker so it went fully around . And yes the speedo cable was dialed in proper had a cop friend help me bring it to where it would not go over 65 . . With my 65 I had the 300 4.9 I6 with 3speed manual transmission with a 682 rear end . My rear end came off a 6ton box truck duell axle my budy converted to a regular 5lug not the 10lug . So that may be a reason I was able to get that speed but who knows give it a shot
Old May 5, 2018 | 03:06 PM
CFValdovinos's Avatar
CFValdovinos
65 MPH
I have a 1960 ford f-100 with a 223 in it. Max speed is about 65 to 70 with no pedal left.
Old May 12, 2018 | 02:45 PM
  #28
1972RedNeck
Old thread, but while we're at it, the HiPo clocked me at 103 MPH when I still had 4.10's. With the current 3.31's, I tend to cruise around 90 MPH but she will do well over 100 MPH id need be.
Old May 13, 2018 | 04:33 AM
  #29
Boss9F100's Avatar
Boss9F100
Only 66 F100 I tried top speed was my dads when nearly new. Getting close to finishing my 66 short bed and it would cruise all day long at 100 mph no problem but don’t think I would have the guts to try top speed.
My 66 f250 would cruise all day @ 100+ with upgraded drivetrain. 125 was fastest I went and would do 105 in a quarter mile. My current 66 with FE should run 115 in 1/4 mile. Same with another 66 f250. Both safely. More so on F100. My daily driver 66 f100 cruises all day no problem @ 80 mph & gets great mpg doing it. It’s all bone stock 352 but has factory T-85. A stock suspension & manual drum brakes not safe much over 80.
Old May 13, 2018 | 04:38 AM
  #30
Boss9F100's Avatar
Boss9F100
My current 66 short bed most likely would hit 140+ Easily but not so sure I would dare. Hope to take it to a standing mile event to do a bit of “testing”
