Power Steering
Old Aug 17, 2011 | 04:38 PM
VR6Nutt's Avatar
VR6Nutt
Power Steering
I am getting ready to swap out a power steering pump due to leaks. Is there anything special to be aware of? I understand that the power steering shares with the braking system...fluid too? Any particular fluid recommendation? Bleeding procedure?
Old Aug 17, 2011 | 06:09 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I used mobile 1 synthetic ATF when I changed my pump. I did the put my wheels on some flashing when you are sawing the wheel back and forth to bleed it trick. Helps to have a bud help you.... Or Bud Light.
Old Aug 17, 2011 | 07:01 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Good thing I saw this, did it a year ago and I have some pointers...
Here's my experience:https://www.ford-trucks.com/forums/9...a-weekend.html
-You will need to remove the alternator and take off the cover it and the powersteering pump are attached to
-You WILL need a powersteering pulley puller AND an impact wrench to get it off
-Use Mobil 1 synthetic fluid to refill
Old Aug 18, 2011 | 09:13 AM
VR6Nutt's Avatar
VR6Nutt
Thanks for the tip! Just read your writeup - WOW. I can't quite tell where the leak is coming from yet as I'll have a bud work the wheel while I lie under the truck to see. So whats the final verdict on fluid? Type F ATF or Mobil 1?
Old Aug 18, 2011 | 02:42 PM
Toreador_Diesel
Use Mobil 1 and if the leak is bad enough, all you'll have to do is start the engine and you'll see where it's coming from. That's all it took for me...
Bullseye72
21
Dec 24, 2014 04:22 PM
Enomra
Jul 10, 2012 01:08 PM
JT250
13
Dec 10, 2011 08:26 PM
lasher
Aerostar
29
Nov 16, 2005 11:45 AM
senseidanf
Aerostar
Jul 25, 2005 02:55 AM
