new power steering pump installed but wrong fluid inserted
Using the wrong fluid is likely asking for eventual problems.
ATF type F is a 20W base oil with anti-foaming additives but no friction modifiers like Dexron III/Mercon transmission fluid or PS fluid.
PS fluids are a 5W weight synthetic oil and this can cause seals to leak that were designed for type F fluid.
https://www.fcsdchemicalsandlubrican...ission%20Fluid
<TABLE border=0 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD height=70 background=images/tile1.gif width=1> </TD><TD background=images/tile2.gif>
</TD></TR><STYLE type=text/css><!--body { background-color: #FFFFFF;}--></STYLE><TR><TD></TD><TD vAlign=top colSpan=2 align=left><TABLE border=0 cellSpacing=0 cellPadding=0 width=690 background=images/Tabs/Tabtile.jpg align=left><TBODY><TR><TD>
</TD><TD>
</TD><TD>
</TD><TD>
</TD><TD>
</TD><TD>
</TD></TR></TBODY></TABLE></TD></TD></TR><TR><TD> </TD><TD vAlign=top colSpan=2 align=left><TABLE border=0 cellSpacing=0 cellPadding=0 background=images/Tabs/Tabtile.jpg align=left><TBODY><TR><TD>
</TD><TD>
</TD><TD>
</TD><TD>
</TD><TD>
</TD><TD>
</TD><TD> </TD></TR></TBODY></TABLE></TD></TD></TR><TR><TD height=20 background=images/Tabs/brake4.gif> </TD><TD background=images/Tabs/brake4.gif>[***************]
[/COLOR] </TD><TD background=images/Tabs/brake4.gif> </TD></TR><TR><TD height=40 background=images/Tabs/trans4.gif> </TD><TD> Power Steering Fluid</TD></TR><TR><TD background=images/Tabs/trans4.gif> </TD><TD vAlign=top><TABLE border=0 cellSpacing=0 cellPadding=0 width=779><TBODY><TR><TD vAlign=top width=179>
</TD><TD vAlign=top width=600><TABLE border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD><TABLE border=0 cellSpacing=5 cellPadding=0><TBODY><TR><TD vAlign=top>
</TD><TD>Recommended for all power steering systems which require MERCON<SUP>®</SUP>V fluid</TD></TR><TR><TD vAlign=top>
</TD><TD>Recommended for all power steering systems previously serviced with MERCON<SUP>®</SUP></TD></TR><TR><TD vAlign=top> </TD><TD>Note: All power steering systems built after 1998 require the use of MERCON<SUP>®</SUP>V fluid.</TD></TR><TR><TD vAlign=top>
</TD><TD> </TD></TR></TBODY></TABLE></TD></TR><TR><TD vAlign=top><TABLE border=0 cellSpacing=15 cellPadding=0><TBODY><TR vAlign=top><TD vAlign=top><TABLE border=1 cellSpacing=0 borderColor=#000000 cellPadding=3 width=550><TBODY><TR bgColor=#990000><TD colSpan=10>
</TD></TR><TR><TD width=110>
</TD></TR></TBODY></TABLE></TD><TD vAlign=top align=left><TABLE border=0 cellSpacing=15 cellPadding=0 width=75><TBODY><TR><TD vAlign=top align=left><TABLE border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD vAlign=top align=left><TABLE border=1 cellSpacing=0 borderColor=#000000 cellPadding=0 width=75><TBODY><TR><TD bgColor=#990000 width=75>
</TD></TR><TR><TD width=75>
</TD></TR></TBODY></TABLE></TD></TR><TR><TD align=left>
</TD></TR></TBODY></TABLE></TD></TR><TR><TD align=left><TABLE border=1 cellSpacing=0 borderColor=#000000 cellPadding=0 width=75><TBODY><TR><TD bgColor=#990000 width=75>
</TD></TR></TBODY></TABLE></TD></TR><TR><TD>
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TABLE><MAP name=Map><AREA href="category.asp?select=%5BMotorcraft%20Motor%20 Oil%20and%20ATF%5D" shape=rect coords=8,6,123,43><AREA href="category.asp?select=%5BOils%20and%20Lubrican ts%5D" shape=rect coords=130,7,244,42><AREA href="category.asp?select=%5BSealers%20and%20Adhes ives%5D" shape=rect coords=251,7,365,41><AREA href="category.asp?select=%5BCleaners,%20Waxes%20a nd%20Polishes%5D" shape=rect coords=374,7,488,42><AREA href="category.asp?select=%5BA/C%20System%20and%20Engine%20Cooling%20System%20Pro ducts%5D" shape=rect coords=496,7,610,42><AREA href="category.asp?select=%5BMaintenance,%20Paint% 20and%20Special%20Products%5D" shape=rect coords=618,7,733,40></MAP>
I'm thinking it would be best to use Type F.
So IMHO the OP should remove that fluid he put in,put in Type-F,and re-bleed the system.
Type F ATF is designed for older transmissions and is used in older power steering systems designed to use Type F fluid and is dyed red. Power steering fluid is only designed for power steering systems, is a lighter weight oil than type F and isn't compatible for use in transmissions. It's also clear, not red.
ATF, brake fluid and PS fluid are all hydraulic oils but, they do not share the same properties, base oils or additives. Each has its own Saybolt Universal Second for flow of viscosity.
Type F ATF doesn't contain friction modifiers. Mercon/Dexron ATF does contain friction modifiers.Type F is less 'slippery' than Dexron/Mercon ATF.
If your Ford PS pump was designed before 1996/'98, it was likely designed for type F ATF (however, always consult your owners manual for the specified fluids and fill capacities). If whatever is being poured in the power steering pump/system doesn't have specification ESW-M2C33-F on the bottle label, it's not designed for the older power steering systems.
QUOTE]
I don't want to turn into dualling banjos here Ultra,but the "clear" P/s fluid you reference is for modern Ford vehicles. Not Dents and older. You are talking about Motorcraft part number XL-14. Used to have a part number something like F7AZ3F823B off the top o' my head. Don't have time to research. Gotta punch out and go home. Got Christmas stuff a happnin'.
QUOTE]
...if not Dueling Banjos, how 'bout a little Foggy Mountain Breakdown instead?
Flatt & Scruggs - "Foggy Mountain Breakdown" | Gr…:
....you know I'm just messin' with you?
