Free cupholders....
If anyone has any ideas as to what may be the problem, any help is appreciated.
Waxy
I have the instructions to fix.
I just saw this thread and it will be deleted
If you are getting D:\ Not accessible or Not ready .
This article was previously published under Q166013
SYMPTOMS
When you start your computer, you may receive the following error message:
<drive letter>:\ is not accessible.
The device is not ready.
CAUSE
This behavior occurs when you restart your computer without closing a Windows Explorer or My Computer window that is displaying the contents of a floppy disk drive if the floppy disk has been removed. The error message occurs when Windows 95 attempts to reopen the window to display the contents of the floppy disk.
RESOLUTION
To prevent this error message, close the Windows Explorer or My Computer window displaying the contents of the floppy disk before you restart your computer.
Last Reviewed: 12/17/2000
Keywords: kbui KB166013
Or
Cause : Program***** file has been tampered with.
go to start
click >find
type in program*****
Find now
SYMPTOMS
When you try to access your CD-ROM drive in Windows, you may experience one of the following symptoms:
You cannot run executable (*****) files.
You cannot view complete directory listings.
You receive the error message "Device not found."
CAUSE
These issues can occur if you are using an older version of the Mscdex***** file that is not compatible with Windows 95 or Windows 98.
When you install certain real-mode CD-ROM drivers, an older version of the Mscdex***** file is copied to the hard disk, and the Autoexec.bat file is updated to point to this older version of the Mscdex***** file.
RESOLUTION
Modify the Autoexec.bat file to reference the correct version of the Mscdex***** file. To do so, follow these steps:
Make a backup copy of the Autoexec.bat file.
Use any text editor (such as Notepad) to open the Autoexec.bat file.
Modify the line containing Mscdex***** to read
<drive>:\<windows>\command\mscdex***** <parameters>
where <drive> is the drive letter on which the Windows folder is located, <windows> is the name of the folder in which Windows is installed, and <parameters> are the parameters from the original line containing Mscdex*****.
NOTE: To maintain compatibility with the installed CD-ROM driver, make sure to use all the parameters exactly as they are used in the original line.
Save and then close the Autoexec.bat file.
Restart your computer.
Last Reviewed:7/24/2001Keywords:kberrmsg kbHardware kbprb KB139428
You may also view instructions at this URL.
http://support.microsoft.com/default...;en-us;Q133240
GIVE ME A BREAK. I didn't blame you at all, like I said, I thought it was funny.
It turned out to be no big deal, I just had to reboot.
Waxy
