Goofy thread title but its all I got. I have the backup camera that comes on in the rear view mirror. Is it possible to hook it up to one of the upfitter switches to turn it on even though I am in drive? It would be nice to be able to activate it while towing to double-check the linkages and hookups in moments of 'holy crap, did i forget to put that pin in?'
Yes you can but if my guess is right might only work from manual turn on but not reverse feed( might turn on reverse lights when manual switch is on ill get the color codes for ya when i get home
you need to grab a diode. A diode acts like a check valve. Only allows current one way. run a wire from your upfitter switch to the trigger wire on the camera
I only have a 2009/2010 Workshop DVD. I'll look at it later and see what the trigger wire is for the Rear Mirror Camera. There is a wire from the Inst. Cluster that runs to the Rear Mirror. This triggers the LCD display on, which in turn powers the Rear Camera on.
You wire the diode so that you don't reverse feed that trigger wire. That way, whenever you flip the upfitter switch, the mirror/camera is turned on.
I'll post up pics in a few hours of the Wiring Diagram.
edit: btw, that write-up you posted up is amazing 1975StroppeBaja! I hadn't even considered doing an electronic 4x2 low range. I was just going to install manaul hubs
Thanks!! The low range 4x2 works great and comes in real handy occasionally.
Photobucket is fighting me right now, so I can't post a picture. My Ford Service DVD only covers the 2009 models, so hopefully your 2011 is similar.
Your camera should have 10-11 wires in it's harness.
Blue: Key On Power
Blue-Gray: Compass -
Gray-Blue: Compass +
Green-Brown: Reverse Signal
Yellow-Green: Microphone +
Blue: Microphone -
White-Green: Drain
White-Green: Video +
Brown-Violet: Video -
Black: Ground
The wire you want to tap into and use the Diode on is the Green-Brown wire. This will trigger the mirror into thinking the truck is in Reverse and will turn on the camera and LCD.
edit: got FTE photo thingy to work 1/2 way. keeps resizing smaller
as you can see from the diagram above (the bottom one), the camera is on anytime the truck is running.
so it's simply a matter of triggering the LCD display to turn on. simple and effective. I'm glad you asked this question because I am installing a 2009 F-150 camera into my F-250 right now and these diagrams are priceless. I was going to have to do the research anyways
I did this mod this weekend on my 2010 F350 with the factory camera and the screen in the mirror. The Green wire with the brown tracer is the wire to do this. I accessed this from the main connector behind the passenger side A post kick panel. Wired in the diode and ran a wire under the dash to the #3 upfitter switch. Works like a Champ!!
