1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Backup camera manual switch on?
Old 08-17-2011, 08:40 AM
BCM's Avatar
BCM
BCM is offline
Goofy thread title but its all I got. I have the backup camera that comes on in the rear view mirror. Is it possible to hook it up to one of the upfitter switches to turn it on even though I am in drive? It would be nice to be able to activate it while towing to double-check the linkages and hookups in moments of 'holy crap, did i forget to put that pin in?'
Thanks boys.
Old 08-21-2011, 04:34 PM
BCM's Avatar
BCM
BCM is offline
Nothin'? Beuller?
Old 08-21-2011, 04:41 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Check out this thread if you haven't already. A couple of the members in there have something similar to what you're talking about.
https://www.ford-trucks.com/forums/6...amera-yet.html
Look down toward the more recent posts. The thread was started in 2007 but was resurrected about a week ago with new posts and info.
Old 08-21-2011, 04:43 PM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
Is it an aftermarket backup cam or the OEM one?
If its aftermarket then yes, it should be easy to do this. If its OEM then I don't know about finding the wires and such.
Anyhow, I have mine rigged up so I can manually turn it on. There's some info about how I did it on my webpage here:
2004 F250 Auxiliary Switch Install
Scroll down to page 2 of the schematics and you'll see how I have it connected up with diodes and such. Works like a charm.
Edit -- some more info about the actual camera installation here:
http://www.frontiernet.net/~jmray/F250BackupSensors.htm
Old 08-21-2011, 04:44 PM
BCM's Avatar
BCM
BCM is offline
It is the OEM one. Man, am I loving that thread ps72 put up. Off to check out yours now, Baja. Thanks, man.
Old 08-21-2011, 06:29 PM
HASBROUCK's Avatar
HASBROUCK
HASBROUCK is offline
Yes you can but if my guess is right might only work from manual turn on but not reverse feed( might turn on reverse lights when manual switch is on ill get the color codes for ya when i get home
Old 08-21-2011, 06:30 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
you need to grab a diode. A diode acts like a check valve. Only allows current one way. run a wire from your upfitter switch to the trigger wire on the camera
I only have a 2009/2010 Workshop DVD. I'll look at it later and see what the trigger wire is for the Rear Mirror Camera. There is a wire from the Inst. Cluster that runs to the Rear Mirror. This triggers the LCD display on, which in turn powers the Rear Camera on.
You wire the diode so that you don't reverse feed that trigger wire. That way, whenever you flip the upfitter switch, the mirror/camera is turned on.
I'll post up pics in a few hours of the Wiring Diagram.
edit: btw, that write-up you posted up is amazing 1975StroppeBaja! I hadn't even considered doing an electronic 4x2 low range. I was just going to install manaul hubs
Old 08-21-2011, 08:06 PM
1975StroppeBaja
Thanks!! The low range 4x2 works great and comes in real handy occasionally.
Old 08-22-2011, 11:45 AM
Bdox's Avatar
Bdox
Bdox is offline
Does the reverse switch control the power supply to the camera or does it switch the ground?
Old 08-22-2011, 02:00 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Photobucket is fighting me right now, so I can't post a picture. My Ford Service DVD only covers the 2009 models, so hopefully your 2011 is similar.
Your camera should have 10-11 wires in it's harness.
Blue: Key On Power
Blue-Gray: Compass -
Gray-Blue: Compass +
Green-Brown: Reverse Signal
Yellow-Green: Microphone +
Blue: Microphone -
White-Green: Drain
White-Green: Video +
Brown-Violet: Video -
Black: Ground
The wire you want to tap into and use the Diode on is the Green-Brown wire. This will trigger the mirror into thinking the truck is in Reverse and will turn on the camera and LCD.
edit: got FTE photo thingy to work 1/2 way. keeps resizing smaller
Old 08-22-2011, 02:03 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
as you can see from the diagram above (the bottom one), the camera is on anytime the truck is running.
so it's simply a matter of triggering the LCD display to turn on. simple and effective. I'm glad you asked this question because I am installing a 2009 F-150 camera into my F-250 right now and these diagrams are priceless. I was going to have to do the research anyways
Old 08-22-2011, 02:04 PM
BCM's Avatar
BCM
BCM is offline
Awesome stuff, tylus... thank you!
Old 08-22-2011, 03:43 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
no problem. I just hope they didn't change much out from the 2010 to the 2011 during the redesign.
Ford likes to re-use stuff. Chances are that harness stayed the same
Old 09-06-2011, 05:57 PM
Andrew010's Avatar
Andrew010
Andrew010 is offline
Anybody know what wire is the trigger wire for the backup camera for the navigation screen?
I have the backup camera in my navigation screen and would really like to do this upgrade.
Thanks guys.
Old 09-13-2011, 06:31 AM
ahco4693's Avatar
ahco4693
ahco4693 is offline
I did this mod this weekend on my 2010 F350 with the factory camera and the screen in the mirror. The Green wire with the brown tracer is the wire to do this. I accessed this from the main connector behind the passenger side A post kick panel. Wired in the diode and ran a wire under the dash to the #3 upfitter switch. Works like a Champ!!
Quick Reply: Backup camera manual switch on?
