Sponsored by: Real Truck
Backup camera manual switch on?
Old Sep 13, 2011 | 07:16 AM
BCM's Avatar
BCM
Can't wait to find out if I'm going to be keeping my vehicle or not so I can get this done.
Old Sep 13, 2011 | 06:52 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Originally Posted by BlueCrystalMan
Awesome stuff, tylus... thank you!
hey, as a FYI for the 2011 guys
2008-2010 cameras and mirrors are different from 2011 models
Ford changed the wire colors and on the mirror, they switched the pinouts slightly.
Here is the mirror pinout (and wire colors) you need for your 2011. I installed this setup in my 2006 about 2 weeks back and ran into alot of problems until I figured out what was going on
Please ignore all the handwriting
Old Nov 21, 2011 | 06:28 PM
tabasco's Avatar
tabasco
This is perfect information but how do you locate this connector?
Old Nov 21, 2011 | 07:16 PM
rs4-380's Avatar
rs4-380
Originally Posted by Tylus
I am installing a 2009 F-150 camera into my F-250 right now and these diagrams are priceless. I was going to have to do the research anyways
Is that an in-mirror setup ?
Old Nov 21, 2011 | 08:45 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Yes, in mirror
Old Nov 21, 2011 | 09:43 PM
rs4-380's Avatar
rs4-380
Yes, in mirror
would love a heads up when you've got it complete
Old Nov 22, 2011 | 07:50 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
my setup is complete. I've had it working since August. I used 2010/2011 mirror and camera from a F-150. Had to custom wire from tailgate to mirror though since the F-150 harness won't work obviously in my truck.
I'm currently re-wiring the tailgate to add a door lock solenoid. If I remember, I'll try to make a short video of the reverse cam setup
Old Nov 22, 2011 | 11:45 AM
jmiley's Avatar
jmiley
I have a 2012 F250 with the in dash Navigation, with the back up camera, how can I use an upfitter switch to turn it on while I am driving?
Can I add additional cameras to the system?
Thanks.
Old Nov 22, 2011 | 03:29 PM
rs4-380's Avatar
rs4-380
do you need the ford camera of can you use any rca out camera with the mirror?
Old Nov 23, 2011 | 10:23 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
You can use any camera you want. The mirror uses a + & - input. So simply run that to the right pins on mirror and your golden.
Old Jun 28, 2012 | 02:29 PM
jdenny21's Avatar
jdenny21
What type of diode do you need to do this and where can you get one, radio shack? Thanks for your help.
JD
you need to grab a diode. A diode acts like a check valve. Only allows current one way. run a wire from your upfitter switch to the trigger wire on the camera
I only have a 2009/2010 Workshop DVD. I'll look at it later and see what the trigger wire is for the Rear Mirror Camera. There is a wire from the Inst. Cluster that runs to the Rear Mirror. This triggers the LCD display on, which in turn powers the Rear Camera on.
You wire the diode so that you don't reverse feed that trigger wire. That way, whenever you flip the upfitter switch, the mirror/camera is turned on.
I'll post up pics in a few hours of the Wiring Diagram.
edit: btw, that write-up you posted up is amazing 1975StroppeBaja! I hadn't even considered doing an electronic 4x2 low range. I was just going to install manaul hubs
Old Jun 28, 2012 | 05:31 PM
1975StroppeBaja's Avatar
1975StroppeBaja
I used 1N4001 diodes. The radio shack website says they have them...
1N4001 Micro 1A Diodes : Diodes | RadioShack.com
Old Jun 28, 2012 | 09:36 PM
  #28
caddy's Avatar
caddy
I have the back up camera on d tailgate. I installed the Lockpik on my truck to bypass nav input and DVD player while driving. Other benefit was I can also view my rear camera while driving to check on my trAiler. Pretty good buy for what it enables. Also gives option to add another camera if you wanted to. No cut wires just plugs into nav harness.
Old Jun 29, 2012 | 03:00 AM
  #29
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I'm wanting to grab a factory nav unit for a 08 and put into my truck with a lockpick
Old Jul 15, 2012 | 11:12 PM
  #30
sandfarmer's Avatar
sandfarmer
So I'm looking at that schematic but not exactly sure which wire I'm looking to tap into on a 2011 in mirror camera. Could someone just simply let me cheat and spit out the answer! LOL, Thanks!
