Stuck Distributor
Old Aug 17, 2011 | 07:46 AM
76F15OSuper's Avatar
76F15OSuper
Stuck Distributor
I have a 400ci in my truck.The Distributor is stuck.
The housing of the distributor got broke while a buddy of mine was pulling the intake off. I bought a new distributor but the old one will not come out.
I have removed the retaining bolt. Soaked it down with penetrating oil. But the Distributor will not come out of the engine
Old Aug 17, 2011 | 08:17 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Soak with PB Blaster and get it turning. They can get corroded since it's aluminum against steel.
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Keep soaking try PB blaster, since the housing is already broke can you get a pipe wrench on it? Or a chain wrench, back and forth pressure and tap with a hammer?
It might take a BIG tap with a big hammer, since you already have a new one....
If you have a a/c bracket probably not, you can try a special plumbing wrench for getting up under the sink. Its has a 90 degree spring loaded collar, hardware store for it.
Also might try a kit called "freeze off', most auto parts stores carry it.
CRC Industries Freeze-Off® 5002 - Super Penetrant | O'Reilly Auto Parts
Old Aug 17, 2011 | 09:54 AM
mark a.'s Avatar
mark a.
You may have to drop the oil pan and beat it up through if all else fails.
Old Aug 17, 2011 | 09:57 AM
thekingofcows's Avatar
thekingofcows
I had this happen once, definately soak
with pb blaster then if you can get a crow bar under the housing you can prolly pry it out. I took my ac compressor off and with the ac bracket as the fulcrum.
Old Aug 17, 2011 | 10:29 AM
POPAJON's Avatar
POPAJON
When you replace the distributor, smear some never seize on the shaft that touches the block. This will help in preventing it from seizing to the block. I do this to ALL my distributors and have never had one get stuck on me. john
Old Aug 17, 2011 | 10:32 AM
76F15OSuper
I did take the Ac compressor off and using the mounting base as a pry point.
I was flexing a tire iron on it trying to get it loose
Old Aug 17, 2011 | 10:41 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Don't waste your time trying to pull till you get it turning.
Old Aug 17, 2011 | 11:05 AM
thekingofcows
I believe it took around a week of soaking a few times
a day in on blaster befor I ever got mine to break loose.
Capecoraldad
16
Apr 21, 2018 08:51 PM
Speedymaru
67
Aug 14, 2016 11:43 AM
green 1969 f100
Mar 27, 2005 05:52 PM
eandaauto
Jun 1, 2004 11:17 PM
Matt
Dec 17, 1999 02:27 PM
