Sponsored by: Real Truck
what happened???
Old Aug 15, 2011 | 05:18 PM
dchamberlain's Avatar
dchamberlain
Yes. That's called the multi-function switch. The 4 way switch is also part of it. It's all one big unit in the column.
Old Aug 15, 2011 | 05:23 PM
2003 f-250's Avatar
2003 f-250
can you give me some dircetion on the steps to replace it? I assume that the steering wheel has to come off? Figures, just got everything back together fixing my cruise contol....
Also do you suggest one from ford, napa, or autozone???? I'm gonna see what ford wants for it tomorrow after work.
thanks,
Robert
Old Aug 15, 2011 | 05:25 PM
kd0axs's Avatar
kd0axs
I guess multi function switch is the proper name since it controls quite a bit more than just the turn signals. The fact that the hazards in the front also don't work pretty much confirms that it's the problem.
Old Aug 15, 2011 | 05:30 PM
dchamberlain
Ford is the only place you will find it. It's not real cheap. PartsGuyEd has it for about $95.
Go to www.partsguyed.com and search for Ford part # 4C3Z13K359AAA.
I'll print the service procedure and attach it here. It doesn't look too hard.
File Type: pdf
Old Aug 15, 2011 | 05:36 PM
2003 f-250's Avatar
2003 f-250
wow, that's much more simply than I thought. Figured that you'd have to take off the steering wheel. anyhow, no wonder our trucks are so easy to steal.... look @ how you take the cylinder lock out!!!!
Thanks so much for the instructions and the link.
Robert
Old Aug 17, 2011 | 01:15 PM
2003 f-250's Avatar
2003 f-250
okay, I'm not argueing the fact that the switch is bad....
BUT,
Can someone explain to me why suddenly everything decided to work yesterday? I still plane on replacing the switch, just not as soon now since i really don't have the time till the end of next week (I work all week and this whole weekend).
thanks,
robert
Old Aug 17, 2011 | 01:20 PM
dchamberlain
It may just be dirty, corroded or worn contacts that started making contact again.
I don't know, because I've never taken one out, but it might be possible to disassemble it and clean all the contacts. It's a complex switch though, and it might be way to complex to ever get back together again. And it might shoot 1/2 dozen springs all over your shop that you can find again in the process.
Old Aug 17, 2011 | 02:09 PM
2003 f-250's Avatar
2003 f-250
I'll make you come and help me then because I'll never be able to find any of them lol! When I get time I'll take it out and see if it'll even come apart. I did find on napa's web site that they do have the switch....but it's $110 at my local napa.....
Thanks again.
Robert
projectdagger
Nov 19, 2012 05:35 AM
ds086121
Mar 2, 2010 11:06 PM
*2fords*
Nov 24, 2009 09:25 PM
RangerPilot
General Automotive Discussion
May 27, 2006 05:30 PM
joepechin
1983 - 2012 Ranger & B-Series
Oct 7, 2004 06:11 AM
