Intermittent brake light failure
Old Oct 5, 2004 | 12:27 PM
joepechin's Avatar
joepechin
My 1999 Ranger brake lights are failing intermittently. You can depress the pedal and the lights will initially shine normally but, after a few seconds, go out. I recently installed a Hoppy trailer harness with a built in taillight converter. The harness was of modular construction and installed easily. To be honest, I am not sure if I had the problem prior to installing the harness. Any ideas you can share will be greatly appreciated.
Thanks!
Joe
Old Oct 5, 2004 | 07:55 PM
Ken00's Avatar
Ken00
I would pull the trailer connector out to eliminate that as the cause.
Old Oct 5, 2004 | 09:49 PM
joepechin's Avatar
joepechin
Thumbs up
I pulled the brake light switch and opened it up. Inside were three sets of contacts. I cleaned one set that showed signs of arcing with emery paper and it seems to have solved the problem. I'll probably order a new switch just in case. Thanks!
Old Oct 6, 2004 | 07:44 PM
Ken00's Avatar
Ken00
Glad to hear things are better now!!
Old Oct 7, 2004 | 06:11 AM
bcjim's Avatar
bcjim
Amazing, I was just about to post with the same symptoms, although I have no trailer wiring.
Anyone know the difficulty level of switch replacement and/or the cost of the switch?
