Emergency Brake Issue
Old Aug 14, 2011 | 02:25 PM
4x484150's Avatar
4x484150
Allright, so my truck has a 3" body lift on it-came with it when I bought it. The front emergency brake cable was stretched to the max. I took it off, found out the plastic coating had broke and was binding in the casing. Im getting a new cable, but my question is, should I put the cable in the factory spot, make new bracket to bolt to the cab, or get a longer cable? Or a different option? Thanks in advance!
Old Aug 15, 2011 | 07:26 PM
Gary Lewis's Avatar
Gary Lewis
If I understand correctly you don't have enough adjustment on the bolt where the front cable connects to the rear cables. If that's the case, how about using a piece of all-thread and a coupling nut to lengthen the existing bolt?
And, just in case you don't know, a coupling nut is a nut about 4 times longer than a standard nut and is used to connect two threaded devices, like bolts. Lowes usually has a supply of them. But, if you go this way you should either use jam-nuts either side of the coupling nut or Loctite the bolt & all-thread into the coupling nut.
This way you should be able to use all stock cables but still get plenty of adjustment.
Old Aug 16, 2011 | 08:06 PM
4x484150's Avatar
4x484150
Thanks for the suggestion Gary. But I have enough cable to get the adjuster fine tuned. See, the front cable housing isnt long enough due to the body lift. It has a nasty curve in it, which caused the failure. Im trying to figure out a way to make a nice bend with out a kink in it. I had wrong wording in my first post, sorry for the confusion!
Old Aug 16, 2011 | 08:15 PM
Gary Lewis's Avatar
Gary Lewis
Ahhh! Now I understand the problem. And, I don't have an immediate solution. All I'm coming up with is to replace the cable with a custom-made cable that is just the inner part and uses pulleys to keep it positioned.
Old Aug 16, 2011 | 08:23 PM
4x484150's Avatar
4x484150
Hey...great idea! I had tried to make a new bracket out of aluminum, and it kinda worked but that thing bent after the first try. I had bolted it to the bottom of the cab. Ill either try the pulleys or make a stronger bracket, say out of steel. Whaddya think?
Old Aug 16, 2011 | 08:31 PM
Gary Lewis's Avatar
Gary Lewis
I'm not picturing the bracket, even tho I recently took the parking brake mechanism out of my parts truck. Can you describe it a bit?
Old Aug 16, 2011 | 08:41 PM
4x484150's Avatar
4x484150
If I had a picture, I'd post it. Do you know the angled aluminum brackets for a garage door set-up? Well, I took a chunk and made a 90 degree side on one end, and bolted it to the bottom of the cab, and it was roughly 3" above stock location. I could get a picture tommorrow if you wanted, except for I took the old cable off to see what the problem was.
Old Aug 16, 2011 | 09:01 PM
Gary Lewis's Avatar
Gary Lewis
So, you are putting the e-brake foot pedal mechanism on at an angle? And, that would put the cable at an angle, thereby reducing the bend the cable has to make. That sounds like it would work if the bracket were made out of substantial material, but doesn't it put the pedal at an odd angle?
Old Aug 16, 2011 | 09:07 PM
4x484150's Avatar
4x484150
No, see, the bracket holds the opposite end of the cable housing, and its bolted underneath the cab. It basically takes the place of the cable going through the body mount, to raise it close to "stock" location. Its not inside the cab, and the pedal assembly is not touched.
Old Aug 16, 2011 | 09:21 PM
Gary Lewis's Avatar
Gary Lewis
I'm slow, sorry. My excuse is I'm old. I'm going to have to slide under mine in the morning to try to understand. I did slide under it last evening, but looked at the union of the front and rear cables, not where I think you are working.
Wait! My truck's in the garage, not outside. So, I looked. I think what you are doing is rerouting the cable so it doesn't go through the frame - right? I think that should work if made out of stronger material, like a piece of steel angle.
Old Aug 16, 2011 | 09:29 PM
4x484150's Avatar
4x484150
Not a problem. I wouldnt worry about being old, I think that experience of yours helps a lot of people on here. But yes, thats my goal, to re-route the cable. Thanks for the help!
Old Aug 17, 2011 | 12:31 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I would think hard about removing the body lift, and either put a suspension lift on it, or regular parts. A body lift on our trucks look odd. Especially at the front bumper.
Old Aug 17, 2011 | 03:00 PM
4x484150's Avatar
4x484150
I would like to take the body lift off and put on a reasonable suspension, but at the moment funds are low so...it'll have to wait.
Old Sep 14, 2011 | 08:54 PM
4x484150's Avatar
4x484150
All Fixed
E-brake is now issue free! Here's a pic of what I put in there.
Old Sep 14, 2011 | 09:22 PM
Gary Lewis's Avatar
Gary Lewis
Glad that fixed it. E-brake is a must to have. Good job.
kdmcinnes
Jul 16, 2009 08:21 AM
CNC
Apr 25, 2009 03:23 PM
96expblk
Feb 2, 2007 03:51 PM
scottlane
Dec 1, 2005 09:54 PM
MustangGT221
Nov 18, 2005 04:30 PM
