New Loud Engine Noise
Old Aug 14, 2011 | 02:16 PM
rcosta's Avatar
rcosta
Hi, I was driving this morning and out of nowhere, the engine started to emit a loud, sharp and repetitive sound. The sound is related to how much I press on the gas. It sounds very much like something that is muffler related, but when I opened the hood, it sounded like it was coming from the top of the engine. I am bringing it my mechanic first thing tomorrow, but I was planning on using it for vacation on Tuesday. If it does sound like a big thing, I will have to make alternate plans. Thanks as always.
Old Aug 14, 2011 | 03:30 PM
jasoncw's Avatar
jasoncw
Do you have the V10? Does it drive with a miss? If so, it could be a spark plug has popped out.
Old Aug 14, 2011 | 03:32 PM
perryg114's Avatar
perryg114
Maybe you have a manifold leak from a rusted bolt that broke.
Perry
Old Aug 14, 2011 | 03:45 PM
labman1014's Avatar
labman1014
Could be fan clutch. The more u press the gas the more rpms the faster the fan turns making a louder sound.
rcosta's Avatar
rcosta
Thanks. It is a V10. I do hear it at the same time in the cycle (perhaps once every 10 cycles). Maybe that is it. I hope it is that simple. Thanks so much.
Old Aug 14, 2011 | 03:49 PM
jasoncw's Avatar
jasoncw
If it did pop out, the temporary fix is to install a helicoil, since the threads are now likely gone. Also be sure to check the torque on the remaining plugs. If not properly torqued when installed, they can slowly loosen up, then pop out, messing up the threads on the head.
Old Aug 14, 2011 | 04:49 PM
rcosta's Avatar
rcosta
Hi, I just checked and that is what it was. I am hoping my mechanic can do me a favor and fix it tomorrow. If the threads are gone, I assume that might make this a bigger job than just popping in another plug?
Other than the previous owner not setting the proper torque, what else might cause this?
Thanks again.
Old Aug 14, 2011 | 05:37 PM
EXv10's Avatar
EXv10
I believe 90% of it is caused by someone failing to tighten one when changing plugs. Don't drive it, you have a relatively big job to do to restore the threads. With 10 plugs you need to be focused 100% when changing plugs.
rhino_160
Feb 9, 2008 01:08 PM
bronco502
1978 - 1996 Big Bronco
Feb 21, 2004 08:16 PM
87f150v8
Nov 16, 2003 03:12 PM
wgm114
Oct 1, 2003 08:15 PM
jimbo3
Jul 3, 2003 12:57 PM
