Loud "howl" from engine
Old Dec 29, 2007 | 11:06 PM
rhino_160's Avatar
rhino_160
2000 Navigator:
When at a stop light or idling, every once in a while, maybe a few times in a week, i hear a loud "howl" like noise coming from the engine. it goes away the moment i give it gas and doesn't come back for a couple days. any ideas? thanks
Old Dec 30, 2007 | 12:09 AM
TexFinn's Avatar
TexFinn
Noises are always a bit difficult to diagnose online since people use different descriptions for same sounds.
Anyway... Could the "howl" you mention maybe also be described as "whine"? If so, I would suggest a slipping serpentine belt.
Old Dec 30, 2007 | 12:37 AM
rhino_160's Avatar
rhino_160
i agree with the difficulty in describing the noises on here. i don't believe it is a whine sound. imagine a train doing the typical choo choo, then that long chooooooo at the end. it is similar to that and as soon as you apply any amount of gas, it clears and will not come back for a few days.
Old Dec 31, 2007 | 06:27 PM
Gevans17's Avatar
Gevans17
fan cluth locking up?
Old Jan 6, 2008 | 10:02 PM
Dalinica's Avatar
Dalinica
My wife has been going through the same issue. First they thought it might be the coil, replaced coil and gave tune up. Next they thought maybe tranny was the problem since vehicle was stalling when in drive or reverse only. Rebuilt tranny and still having problem. I will see what happens this week. It does not always stall. No codes have been found.
Old Jan 7, 2008 | 06:01 PM
rhino_160's Avatar
rhino_160
found out today it is most likely the Idle air control valve located directly atop the motor. simple to change out. i will be doing it very soon. good luck
Old Jan 11, 2008 | 08:49 PM
Trucker22's Avatar
Trucker22
I have posted that I had a whistle coming from the engine---using a smoke machine we found out it was a poorly fitting air cleaner---
Fram to be exact
also the idler pulley bearing can be bad --- causing unusual noises---
Just some ideas that are cheap and easy to check out
Hope this helps you
Old Jan 11, 2008 | 08:52 PM
Trucker22's Avatar
Trucker22
noises
also the belt tensioner pulley bearing can squeal---same bearing as tensioner---I've replaced both---on 2000 Navigator, 95K
Old Jan 12, 2008 | 07:27 AM
Modified 99's Avatar
Modified 99
It could be the fan clutch engaging. You won't notice it while driving but you will when it is idling.
Old Jan 12, 2008 | 12:17 PM
projectSHO89's Avatar
projectSHO89
It's probably doing what Ford calls "hooting" or what Contour owners lovingly call "moosing".
It's due to an air resonance in the intake tract, usually at idle, when the IAC valve is in certain positions.
Steve
Old Jan 12, 2008 | 01:39 PM
Dalinica's Avatar
Dalinica
Are you doing the work yourself? I have same problem even after all this work I had done in the last month. I am trying to find the part # so I can pick one up and do the work myself. I located the problem, the hose is pretty much worn out and vacuums into itself.
Old Feb 9, 2008 | 01:08 PM
rescue 09's Avatar
rescue 09
rhino you are on the right track!! my 2001 was doing the same thing. i changed the IAC valve and the noise stopped. good luck!!
johnny7.3
Jun 19, 2007 09:41 AM
xtmsports
Jun 27, 2005 10:28 PM
Munkey
Dec 21, 2004 11:02 AM
hang10
Dec 11, 2003 03:42 PM
