1978 - 1996 Big Bronco
Loud Noice from Engine Compartment
Old Feb 21, 2004 | 05:21 AM
bronco502's Avatar
bronco502
My 95" Bronco, with 302 engine has a loud noise coming from the engine compartment. I think the A/C Compressor clutch is making the noise because as I am driving down the road you can hear the constant noise and hear something engaging from time to time. Noise is a sort of knocking noise that changes in noise pitch with accelleration. When standing in front of my Bronco, I notice the sound coming from the right side area of engine compartment. Any troubleshooting tips or recommendations as to what I should do short of taking it to a mechanic
Old Feb 21, 2004 | 09:13 AM
BillyBob69's Avatar
BillyBob69
Kinda tough to tell what it is unless there. But from the right side, could be your air pump, (Emmissions garbage), alternator...other things...thats if that is where the sound is coming from. Could try getting a friend to listen with the hood open while you rev it a bit...may help figuring where the sound is coming from.
Old Feb 21, 2004 | 08:13 PM
94Bronco58's Avatar
94Bronco58
Could be the fan clutch?
Old Feb 21, 2004 | 08:16 PM
WhëëlMå1's Avatar
WhëëlMå1
You should get a length of tubing, and use it like a stethoscope. That should help you isolate exactly where this sound is coming from.
Rich
Keny1
Dec 25, 2021 05:13 PM
bulldog97
2004 - 2008 F150
Apr 11, 2016 07:46 PM
PumpDoctor
6.4L Power Stroke Diesel
Jun 16, 2009 06:38 PM
Craig0000
1997 - 2003 F150
Oct 24, 2008 02:53 PM
razormac
Feb 21, 2007 06:52 AM
