04 Stutter
Old Aug 14, 2011 | 02:30 PM
dcon12's Avatar
dcon12
04 Stutter
I have an 04 F250 Super Duty with a motor stutter. I have had a lot of work done in the last year. HPOP, IPR, oil cooler, EGR delete, FICM, Map, EPB, 4 Injectors, and most of the other alphabet. However, I get a motor stutter that causes the whole truck to shake when it reaches cruising speed.
It does not happen all of the time. Sometimes I can go over 100 miles before it starts. Sometimes I will not make it 10. I have changed the oil and filters several times. I have changed them at only 2000 miles. It never happens when I first start it up. It runs great. No smoke, no codes. It has 162,000 miles. I hope I have covered everything. Any ideas??? Thanks in advance. Don
Old Aug 14, 2011 | 02:52 PM
bismic's Avatar
bismic
How long ago was the oil cooler work?
Old Aug 14, 2011 | 02:55 PM
dcon12's Avatar
dcon12
Oil cooler work was done in November. It had the stutter problem before I had any work done on it. I always figured that the work would cure the stutter. But the stutter always returns. Don
Old Aug 14, 2011 | 02:59 PM
bismic's Avatar
bismic
My guess would be turbo related. A 2005 I had did the same thing - it had been sitting on the lot for quite awhile before I bought it.
Old Aug 14, 2011 | 03:02 PM
BLADE35's Avatar
BLADE35
do you have any gauges
Ittermitened problems suck
Great idea Mark couldnt hurt to clean the turbo
Old Aug 14, 2011 | 03:09 PM
dcon12's Avatar
dcon12
The turbo was cleaned in the November shop time. Although I can hear the turbo when it starts, sounds like a dog howling. Don
Old Aug 14, 2011 | 03:19 PM
BLADE35's Avatar
BLADE35
might try checking all the wire harness connections and harness itself for wire chaff loose connections ect....
sounds like you need to find a good diesel tech thats alot of part changing where are you located
Old Aug 14, 2011 | 04:18 PM
bismic's Avatar
bismic
And that is normal to you?
Old Aug 14, 2011 | 04:30 PM
dcon12's Avatar
dcon12
No, but when a shop says they do something, I trust they did. However, maybe they are not an honest shop. Don
Old Aug 14, 2011 | 05:33 PM
dcon12's Avatar
dcon12
So you believe I need a new turbo? Don
Old Aug 14, 2011 | 06:53 PM
bismic's Avatar
bismic
Not necessarily. But if it has been "howling", something is wrong. Are you sure you don't have any codes (what was used to read the codes)? Are you sure you don't have a leak in the CAC system or exhaust? You didn't mention the turbo in post #1, so what was done to it (you mentioned cleaning, but were any parts changed, how did the unison ring look, etc)? Was all of the work required, or was some of it preventative? Has any work been done recently (last month or so)?
shay9165
Oct 11, 2014 12:26 PM
jmtbiggin
Apr 3, 2014 11:04 PM
shivaskeeper
Nov 29, 2013 11:28 PM
PADLER
Oct 20, 2010 05:05 PM
plindsay105
Aug 16, 2010 08:37 AM
