feels like its missing
Old Aug 13, 2011 | 09:45 PM
erik_bishop's Avatar
erik_bishop
my truck has been feeling kinda weak lately. I have noticed that with very little throttle my engine feels like it is missing, it will accelerate, but right where you are just barely pushing on the accelerator pedal, it has a mild barely noticeable sputter, which will go away immediately if push just a bit more on the accelerator pedal, any one have any ideas as to what may cause this ? i am afraid it will get worse.
it cruses fine down the highway at 70MPH. up hills, across flats, with or without cruse control on.
slow speeds is where its happening, up to about 30-45 is where i feel it most, in town driving.
I have 1 psi of boost on the highway at 70 MPH cruising speed across the flats, hit a hill and the boost will go up to 4-5 if you floor it, boost will go right up and black smook will pour out. fuel is expensive so i don't do the pedal to the floor very often.
thanks
bishop
Old Aug 13, 2011 | 10:21 PM
bama29fan's Avatar
bama29fan
Not sure if the sputtering is related but your boost sounds low
snakedoc's Avatar
snakedoc
the TPS my be going out.
if you are only getting 5bls at wot you have a boost leak that will hurt MPG.
Old Aug 14, 2011 | 01:15 PM
erik_bishop
TPS. Throttle Positioning Sensor.
Good I'll go buy one today.
Boost is good. 4-5 up hills with cruz on.
I get 20 PSI very easy with pedal to floor.
Old Aug 15, 2011 | 01:13 PM
erik_bishop
TPS is there more than one?
$220 for the pedal assemblie. Ouch
Old Aug 15, 2011 | 07:34 PM
arcticatdan's Avatar
arcticatdan
Dorman has them part number 699-201 about $50.
Old Aug 15, 2011 | 08:48 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I don't think that part will fix your problem.
Old Aug 15, 2011 | 10:06 PM
jwill8957's Avatar
jwill8957
You need to make sure you get the diesel tps not the one for the gas engine. I have the paper ill look tomorrow
henryjb3363
Mar 12, 2012 06:51 PM
cool2see
Oct 5, 2011 08:20 AM
caprang
6.4L Power Stroke Diesel
36
Feb 27, 2009 01:10 AM
Boss300
Dec 10, 2008 07:20 AM
MTman
Apr 29, 2004 03:10 PM
