Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
!!!!Please Help!!!!
Old Aug 13, 2011 | 09:36 PM
blackmamba's Avatar
blackmamba
Cool !!!!Please Help!!!!
For starters I have a 01 hd F150 with 145000 miles on it....SO a little while ago my truck threw a code of P0320 after it started jerking real bad at around 65mph. I went and got it checked and it was a crankshaft sensor or wiring so I changed it and checked the wiring and connector. Reset the code and it went away, until I put about 13 hours on it and it came right back with the same symptoms. So it kicked the same code so I changed yet another sensor and checked the connectors yet again. Reset it and today it just kicked the same thing, this is driving me crazy any help is much needed! thanks
Old Aug 14, 2011 | 05:25 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
You need to check the wires to the sensor plug. I've seen em get brittle and break inside, but the insulation looks fine so it's hard to find. Just a possibility.
Old Aug 19, 2011 | 11:07 AM
blackmamba's Avatar
blackmamba
Thanks for the tip. it seems that everything was okay, and wouldnt you know it the code cleared itself so here's to hoping the the computer got itself together and it was just a bad glitch.
Headviking
2009 - 2014 F150
Apr 1, 2019 01:39 PM
Brian Hughes
1997 - 2003 F150
Sep 22, 2015 12:16 PM
tinman565
Jun 1, 2011 01:17 PM
Storm
3.8 & 4.2L V6
May 13, 2006 02:55 PM
jerry7187
3.0L V6
Oct 30, 2005 10:16 AM
