Cleaning head bolts?
Old Aug 13, 2011 | 10:22 AM
Myfreeford's Avatar
Myfreeford
75 460 - stock D3VE heads.
What is the best way to clean stock head bolts? I want to be sure and get them as clean as possible before installing them again.
I will be sure to dip them in oil before they are installed, but how do I actually clean them without causing any damage to them? Soak them? Carb cleaner? WD-40? Simple green?
Thanks for any suggestions.
Old Aug 13, 2011 | 10:42 AM
mark a.'s Avatar
mark a.
Wire brush on a bench grinder.
Old Aug 14, 2011 | 03:31 PM
monsterbaby's Avatar
monsterbaby
then blow them off with an air hose or if you really feel the need little bit of brake clean then the air hose but I usually just hit with the wire wheel, then air hose and call it good.
joegeds
Oct 3, 2018 07:08 AM
mulletmaster55
Feb 22, 2005 01:29 AM
HenryFord
Feb 26, 2004 11:47 PM
frankster123
Mar 3, 2003 05:24 PM
