head bolts, replace them or what?
Old Mar 2, 2003 | 08:12 PM
frankster123's Avatar
frankster123
when i removed the heads from my 351m, some were extreamly tight, some had heads so corroided i had to use a metric socket to get them off.
i want to replace all of them. where can i get new replacement head bolts?
also, would it be a good idea to run a thread tap into each hole to clean them up?
when i put it together, would applying a bit of anti-seeze to the threads be a good idea?
thanks for your advice!
Old Mar 2, 2003 | 10:09 PM
GT40man's Avatar
GT40man
arp bolts, you can get them at any speed shop
Old Mar 3, 2003 | 12:10 AM
macguyver's Avatar
macguyver
Definitely re-tap the holes. If they are dirty you won't get an accurate torque reading.
Old Mar 3, 2003 | 11:26 AM
Bill_Beyer's Avatar
Bill_Beyer
Run a tap down into each hole after the block has been tanked and then blow out the holes with compressed air. Get yourself a set of ARP head bolts and read the directions for installing them. They use different tq ratings depending upon whether you coat the threads with straight motor oil or use the special ARP moly lube.
Old Mar 3, 2003 | 05:14 PM
frankster123
so, what are arp bolts? what does arp stand for?
Old Mar 3, 2003 | 05:24 PM
Bill_Beyer's Avatar
Bill_Beyer
Automotive Racing Products
Here is their website
