D20 questions
Old Aug 12, 2011 | 08:50 PM
70truck's Avatar
70truck
D20 questions
I'm still toying with swaping a D20 onto my mated 435/D21 combo. But I have a few more questions. What is the difference between the "T" handle and the "J" pattern? Which is better? And Why? Also to install the D20, will I have to add or change any brackets? And I read the driveshaft has to be modified. Is that true? If so, How? Thanks
Old Aug 13, 2011 | 12:59 AM
DrainBramage's Avatar
DrainBramage
My brothers Bronco has the J Shift Dana20 T-case, can't really say if one is better than the other or not. The 'hot upgrade' for a D20 of any shifter flavor is a BC Broncos Twin Stick Shifter. All the D20s I've had a chance to play with were fickle and can be tough to shift, the one twin stick I played with seemed really nice.
You might jump over and ask in the FTE 66-77 Early Bronco section. These guys have forgotten more about the D20 than I will ever know.
As to your other questions, I don't really have answers. Good luck and let us know how it turns out!
Old Aug 15, 2011 | 10:06 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
"T" shift is a straight line shifter with a lower low range ratio. "J" shifter, you usually have to hunt a bit for the gears. I prefer the "T", but the "J" is easier to twin stick. I have not done this swap in your vehicle. Doing the swap in my Bronco, I used your tranny, a 1" adapter($200), and a six cylinder intermediate housing and shaft from an early Bronco. This put everything back in the same exact location. Hope this helps you somewhat. Shame you're not just a little closer, we'd do the swap.
Ken Blythen
Jan 9, 2013 12:14 PM
shapechanger101
Aug 10, 2012 07:32 AM
JRS2
Aug 28, 2011 11:02 AM
TheBlackRhombus
1978 - 1996 Big Bronco
Jun 18, 2003 02:04 PM
