Reverse Wire for 2007 Expedition
Old Aug 12, 2011 | 05:29 PM
wells2's Avatar
wells2
I have a 2007 Expedition with a flat four wire trailer plug. I bought a boat with a flat 5 wire plug and it has a reverse solenoid. I started to change out the four wire plug to a five wire plug but the blue wire which was taped to the harness wiring is not hot. I checked all the relays and fuses under the hood and in the fuse box and all are correct. Is there something else to do or to check? Thanks.
Old Aug 12, 2011 | 07:52 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I believe to get the back-up lights, you have to tap in to one of the trucks back-up's and run a wire from there.....
Old Aug 12, 2011 | 08:12 PM
dchamberlain's Avatar
dchamberlain
The blue wire is probably the brake controller wire. It goes to the brake controller connector under the dash.
Unless there are other wires down there for 12V power and backup lights, you'll have to run those separately.
tjc transport
Electrical Systems/Wiring
Nov 24, 2014 02:48 PM
ltatkinson
May 20, 2009 05:05 PM
coplin
All Things Towing
May 31, 2007 08:27 PM
frankc29
Apr 24, 2007 06:02 PM
CDSJDS
Nov 26, 2004 11:13 PM
