E350 srs code
Old Aug 12, 2011 | 04:48 PM
Nylongtimer's Avatar
Nylongtimer
E350 srs code
I have a 2004 E350 van with the V10 engine. I had to take it in to have the steering box replaced on Tuesday. I didn't get it back until Wednesday evening and on the way home I noticed the airbag light on the dash. It is a code 19. I called the mechanic who said he didn't do anything to cause that. So, can anyone point me in the direction so that I may repair it myself? I have checked both relay wires under the drivers and passenger seats and both appear to be fine. I did disconnect them and reconnect them but I have the same issue. Thanks to any.
Old Aug 13, 2011 | 02:24 AM
powerstroke72's Avatar
powerstroke72
Moved to correct forum.
Old Aug 13, 2011 | 06:40 PM
rclarke's Avatar
rclarke
An airbag light after a steering gear replacement tells me the mechanic did not lock the steering column at the center while the gearbox was out. The gearbox may not have been installed with both column and gearbox centered. Try the horn. I'll bet the clockspring has been broken.
Old Aug 14, 2011 | 07:16 AM
Nylongtimer
Thanks for the reply. Took truck to store today and the horn does not work, nor does the cruise control. Anyone know of a guide that I can use to replace the clockspring? Thanks.
Bagpiper22
Mar 14, 2015 10:11 AM
bbepristis
Jan 10, 2012 11:29 PM
JohnMcHugh1
Aug 30, 2007 11:03 PM
QIKSTAND
Aug 16, 2007 11:00 AM
evadb
Aerostar
Jan 8, 2005 12:20 PM
