Coolant Loss Again
Old Aug 12, 2011 | 06:44 AM
j-bar's Avatar
j-bar
Coolant Loss Again
Had a bad egr cooler replaced it and the oil cooler and a month later getting rid of coolant again and smells sweet under the hood
Old Aug 12, 2011 | 07:02 AM
bismic's Avatar
bismic
Look for leaks:
degas bottle cap
degas bottle
egr cooler hose
radiator hose
thermostat gsket
water pump
heater hoses
etc
Old Aug 12, 2011 | 07:04 AM
j-bar's Avatar
j-bar
dont see any leaks anywhere
Old Aug 12, 2011 | 08:49 AM
AGE mechanic's Avatar
AGE mechanic
I too had my egr and oil coolers replaced a few months ago. Less than 5K miles later I have the same symptoms. This time its the headgaskets. Not happy...I am going to fix it right this time.
*Edit to correct spelling.
Old Aug 12, 2011 | 09:34 AM
bismic's Avatar
bismic
If you smell coolant, then you have a leak. Maybe it is small, but the smell has to be coming from somewhere .............
Old Aug 12, 2011 | 11:17 AM
AGE mechanic
The coolant smell on mine was from the degas bottle being over pressurised by the leaking headgasket. Is there any dried coolant near or on your degas bottle?
Old Aug 12, 2011 | 10:33 PM
j-bar's Avatar
j-bar
Post
so if its coming from the degas bottle is it more than likely headgaskets or something else.
Old Aug 13, 2011 | 06:45 AM
AGE mechanic
Maybe EGR cooler. Seems like once your problems get started with them, they dont last as long. Those dam oil coolers plug up so quick and trash everything. Mine was the head gaskets this time. I dropped the coin and went to the full BulletProof system with ARP studs. I dont want to get rid of the truck and I dont want to go through this again.
Old Aug 13, 2011 | 01:40 PM
bismic's Avatar
bismic
If the degas bottle cap obverpressures, Ford says it will "weaken" and relieve early. I include this type of situation in the category of a leak because it is not holding what it was intended to.
Head gasket issues after an EGR cooler failure is not uncommon.
nathan66669
May 30, 2015 03:03 PM
Bronco POPO
Feb 9, 2015 06:41 PM
jonnyboy78023
Dec 17, 2013 05:08 PM
Sabbath5.9
Jun 12, 2013 07:14 PM
jim6liter
Dec 24, 2009 10:44 AM
