tranny problem? Need help quick
Old Aug 11, 2011 | 11:15 PM
JustinXTLR's Avatar
JustinXTLR
Alright so my baby is on the side of the road cause i was scared to drive any further. Now for what is happening when i started to go the tranny did not want to shift, once i let out of the throttle it would should up, but then same thing. wouldnt shift again till i let out. Coming to a stop there was this jerk and loud thud. she is very slow like there is something holding her back. it was to dark to check my fluid. Ill look in the morning. But any ideas on where i need to start if the fluid level is good?
Thanks all
Old Aug 12, 2011 | 07:50 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Assuming you have a 2001 7.3L automatic with the original transmission, it's probably the mechanical diode. That's a type of one way clutch.
When the mechanical diode fails the symptom is that it won't shift 1-2 until very high RPM, or until you let off the go pedal. The fluid will probably look fine. The only way to fix this is to rebuild or replace the transmission.
Old Aug 12, 2011 | 09:21 AM
JustinXTLR's Avatar
JustinXTLR
ahhh thats what i was afraid of. now does it make any difference that it was just sudden?
Old Aug 12, 2011 | 09:27 AM
carltonwebb's Avatar
carltonwebb
That what they do . Where in GA are u?
Old Aug 12, 2011 | 09:28 AM
JustinXTLR's Avatar
JustinXTLR
woodstock canton area
Old Aug 12, 2011 | 10:34 AM
Mark Kovalsky
Yes, it does. It confirms that it's the mechanical diode.
Old Aug 12, 2011 | 11:07 AM
JustinXTLR's Avatar
JustinXTLR
okay, so just some more info on the tranny problem. Still the same as last night. fluids were perfect, but now there is some grinding noise. Is that still going to be a mechanical diode and if so, is there a rebuild thread on our trannys somewhere. I really wanna tackle this myself along with a buddy that works on peterbuilts.
Thanks to all for helping me! i freaking love this site.
Old Aug 12, 2011 | 11:31 AM
Brother Les's Avatar
Brother Les
Don't drive it anymore until you find out what is coming apart. Read up on the 'diode' issue and if there is a way to overhaul the tranmission with out replacing the 'diode' section then do that. The 'diode' was only put in for a short time for that year and you should be able to get everything that you need to leave it out.
Do you know how to use the 'search this forum' key? it is on the main 7.3 page..... on the right side, upper, center. type in key words and threads will come up to help you.
Also, some more brothers will be along to help you out.
bottom line.... get rid of the diode parts...
paddler65
May 26, 2010 11:04 AM
Hidalgo
Sep 11, 2008 11:45 AM
gcreed
Aerostar
Mar 8, 2005 09:14 PM
kermit
Florida Chapter
Sep 2, 2004 10:08 PM
panteramatt
Dec 18, 2003 01:49 PM
