Idle Control Module
Old Aug 11, 2011 | 06:57 PM
Major Marvin's Avatar
Major Marvin
Idle Control Module
Hey folks,
I've been looking into the idle control module. I got my A/C fixed just before a recent 850 mile trip. I left my dog in the car for short periods of time with the truck running at idle and the A/C fully cranked. I got back yesterday and I notice that my voltage meter is a bit left of center. If I drive a bit it goes to center or so. The weird thing is that I noticed a loss of power under acceleration. If the batteries are low, does it affect the drive-ability of the engine?
Here's the one I found:
FORD AUXILIARY IDLE CONTROL 7.3L DIESEL NEW OEM | eBay
I figure it will be an excellent accesory for summer and winter, no matter the climate. BTW, I went from sea level to 7000 feet above sea level while on this trip. 60 mph at 2000 rpm's takes patience
Old Aug 11, 2011 | 07:23 PM
superduty4x4's Avatar
superduty4x4
That's not a terrible price, but not a great price either. That bracket is for an SD truck and it might take some modifying to get it to work in an OBS.
Old Aug 11, 2011 | 07:31 PM
Major Marvin
bummer on the bracket but no biggy I'm guessing. Thanks for your reply!
Old Aug 11, 2011 | 09:25 PM
oldbird1965's Avatar
oldbird1965
I wouldn't do it, that's half of a good chip that you could get high idle on.
Old Aug 11, 2011 | 10:06 PM
Major Marvin
Sounds good, what chip and what tunes? I don't really care about extra power due to the fact that I have 4.10's and only cruise at 60 MPH/2000 Rpm's. I wouldn't mind a bump over stock, economy, high idle, no start, stock, and ? You guys are the pros and know who's got what and where. What would be the total cost with tunes? Does it install easily?
$$$ is a major factor but I will not settle for less than the best when it comes to critical components
Thanks
Old Aug 11, 2011 | 10:14 PM
oldbird1965
There's a million threads on that one. I have TW and have a Beans in the mail. I just can't see $200 for a high idle, to me that's wasting money. Its not hard to install at all. Pull the computer, clean the contacts on the end and plug it in. Economy mode might even get you better mileage to pay for the chip and you can have high idle with it.
Old Aug 11, 2011 | 10:22 PM
Major Marvin
Where's the computer? under the dash?
Old Aug 11, 2011 | 10:29 PM
oldbird1965
Behind the emergency brake pedal bracket.
Old Aug 12, 2011 | 03:16 PM
Major Marvin
I took a look at Bean's website ant the 6 position chip costs $599. Is there some other options in regards to vendors and available chips?
ty
Old Aug 12, 2011 | 03:29 PM
fordpride's Avatar
fordpride
Check out PHP power hungry performance. Alot cheaper
Old Aug 12, 2011 | 04:21 PM
Major Marvin
I'm getting discouraged because I can't even find the PCM or code for that matter
Old Aug 12, 2011 | 05:03 PM
fordpride's Avatar
fordpride
Loop in my photos in album 1 and I havE a pic that Shows you. If you look under the brake booster you will see a big wiring harness that goes into the firewall that is where the PCM is
Old Aug 12, 2011 | 05:22 PM
oldbird1965
If you take a few of those little screws out on the fender well and bend the plastic fender well back you can get at the big wire harness. Its a 10mm nut in the middle of the harness that releases the harness. Unplug it and puse it out of the way. Next will be two nuts, top and bottom, holding a gasket type thingee, take it off. Then all you have to do is pull out the PCM and check the code. I hope this all makes sense. If you want a reburn or whatever then you pull the emer brake bracket off and the chip is right there but at first its best to pull it out of there because you have to clean the contacts.
Old Aug 12, 2011 | 05:25 PM
Major Marvin
ty for the heads up.. I seem to need to need pictures and hand signs
Old Aug 12, 2011 | 05:44 PM
fordpride's Avatar
fordpride
You should be able to see the code with a mirrior and flash light
