Idle Control Module
Old Aug 12, 2011 | 05:57 PM
oldbird1965's Avatar
oldbird1965
That's probably true Mike, good point but for him to put a chip in he needs to clean the contacts. Major, I don't have any pictures, but really, its not hard. I'm like you, I need to see it to understand it most of the time. Pull the tire off and remove the whole plastic well cover or a least half of it and bend it back and its even more easy.
Old Aug 12, 2011 | 06:18 PM
427 fordman's Avatar
427 fordman
http://api.viglink.com/api/click?for...13131910228593
I just copied that from the tech mod thread at the top of the page. Good pics of the installation
Old Aug 12, 2011 | 06:34 PM
stainlessstroker95's Avatar
stainlessstroker95
If you just want a high idle puredieselpower.com has one called dfuser. it was $80. I think some one on here got it a while back and it worked good for them. But if your wanting more power too a chip would be the way to go. There is also the home made high idle
Old Aug 12, 2011 | 07:11 PM
fordpride's Avatar
fordpride
Old Aug 12, 2011 | 07:13 PM
oldbird1965
Its always in the most obvious place, good going Darin. I still think its easier from behind the plastic fender well.
Old Aug 12, 2011 | 07:17 PM
427 fordman
I think that is the only way you can actually get it out Glenn is dropping that inner fender down by taking the screws out.
Old Aug 12, 2011 | 08:38 PM
oldbird1965
Oh, I guess I read your link to fast, I thought it was saying to pull it out the top. Its good there is more then one 'brain' on here, LOL.
Old Aug 12, 2011 | 09:57 PM
Major Marvin's Avatar
Major Marvin
You guys totally rock. Within 24 hours I have all sorts of help from extremely knowledgeable folks.
I did run across the 80 dollar high idle deal but the only review on the site said that it didn't work for the 97'. Now I know different. At this point 80 bucks seems affordable and a 6 position chip is quite a bit out of the ballpark financially speaking at this time.
Either way, I surely appreciate all the responses
Old Aug 12, 2011 | 10:27 PM
Major Marvin
Will the one with the screen work? Does it just display RPM's or charge state too? Is it easy to fabricate a bracket or could I velcro it wherever?
Ford Ambulance Auxiliary Idle Control 7.3 Diesel | eBay
Old Aug 12, 2011 | 11:50 PM
stainlessstroker95
I had been looking at the ambulance aic also. I was just wanting a high idle not a chip (my edge is for pulling codes). It would be nice to have a ford high idle but they look too bulky and i dont know where i would put it out of the way. There is also another version of the ford one. I dont think it has the screen and it has less botons.iirc it works by just pushing in the e brake pedal. Now that one you could hide. I found that on ebay too. It was less expensive cause it didnt have a screen. I still havent made up my mind which one i want yet either.
Old Aug 13, 2011 | 06:07 AM
fordpride's Avatar
fordpride
You could do the DIY AIC MOD
North Texas Power Stroke Association - DIY AIC Mod
Old Aug 15, 2011 | 06:37 AM
DIYMechanic's Avatar
DIYMechanic
Originally Posted by fordpride
That's exactly what I did on mine. Cost me less than $20 all told and it works like a champ.
Old Aug 15, 2011 | 09:33 AM
  #28
superduty4x4's Avatar
superduty4x4
Any of them will work in a 7.3.
Old Aug 16, 2011 | 10:47 PM
  #29
Major Marvin
Bought via Ebay and on the way, NIB
I look forward to installing this gizmo.. Just plugs in the to the accelerator pedal harness?
Old Aug 17, 2011 | 11:09 AM
  #30
superduty4x4
No, there is a round plug clipped to the bottom of the dash pointed toward the driver's side that it plugs into.
