6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
fan trouble
Old Aug 10, 2011 | 10:15 PM
alex92's Avatar
alex92
fan trouble
the fan has progressivly started to run more and more.. i have cleaned air filter.. and cleaned radiator what else is there?
Old Aug 10, 2011 | 11:14 PM
galaxie641's Avatar
galaxie641
Fan clutch could just be sticking, does it cycle on and off a lot?
Old Aug 11, 2011 | 05:17 AM
senix's Avatar
senix
Fan is run by sensors that tell it what to do. They have been known to stick. If you are still under warranty you can have it checked but chances are you will need to having sticking when you take it in.
Old Aug 14, 2011 | 08:30 AM
fg250's Avatar
fg250
mine did it for about 3 days and then quit. Has been good ever since.
Old Aug 19, 2011 | 06:25 PM
fruitaboy's Avatar
fruitaboy
My engine fan came on under a hard pull going camping. Shut the truck down camped, started it up on Sunday to go home, fan stayed on the whole way home!! About 2 miles from my house the pos released and has been fine ever since. Called Ford and cant do anything about it if it is not broke! I asked the service writter if they had seen any common failures, but he did not have a clue.
Old Aug 20, 2011 | 07:40 AM
Gearitis's Avatar
Gearitis
Right now, My fan is coming on way more often than normal. Just yesterday, I was coming in from work, doing 75 on I 35, the fan started. It was 107 air temp, hwy temp way higher. When I got off the interstate it stayed engaged for the next 4 miles driving 35 mph till I got home. But again it is hot outside here. This summer, when I was in Colorado, it would also stay on especially in higher elevations. Even though it was 75 or so, it still stayed on and lasted nearly the week I was there. It kept my attention but once I got down to Pueblo, it was intermitted. I had the fan changed last spring on Fords dime so it was a rather new fan assembly. Most say that it is controlled by sensors, but my Job 1 has a Thermal Fan Clutch. The Ford Diesel Tech said you know that by when you start it up, the fan will normally engage until you reach a certain RPM.
If you can spin the fan and it turns 3 times or more freely or if you cannot turn the fan by hand then I would have the fan clutch checked. The following is a link that may help with fan clutches if it is a Thermal controlled silicon based clutch.
Fan Clutches
Old Aug 23, 2011 | 04:25 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Fan Clutches
Are you sure you don't have a electronic lock up fan? Mines a 08 and I have electronic fan lock up.
jrenter
May 5, 2007 08:37 AM
factory594x4
Mar 11, 2007 12:15 PM
fling
Jun 2, 2005 09:47 AM
agelder
Aerostar
Aug 7, 2003 01:00 PM
wytfut
Aerostar
Jul 6, 2001 09:36 AM
