cooling fan
Old Jun 1, 2005 | 07:13 PM
fling's Avatar
fling
cooling fan
Where can i get a heavy duty fan clutch, fan, and shroud for my 68 F250 428" FE? Currently i have the parts to attach the fan solid but i would rather have a clutch. thanks
-Phill
Old Jun 1, 2005 | 09:21 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
I have a 68CS with 410 (427LR heads) that has a 5 row stagger radiator, fan shroud and stainless flex fan. Clutch fans suck (my opinion only).With a 180 stat never had a overheating problem. The shroud is a must.
.....=o&o>.....
Old Jun 2, 2005 | 12:29 AM
Fomoko1's Avatar
Fomoko1
Agreed that clutch fan may not be the best but the one in my 67 Mustang, 390 engine with a 428 crank works good. You could try a large parts store chain to get the clutch fan as most likely Ford will not still have it.
Old Jun 2, 2005 | 01:13 AM
VirginiaWiFinder's Avatar
VirginiaWiFinder
A fan shrowd and flex fan are on my agenda too... I plan to hit the bone yard armed with a few wrenches and a tape measure. I'm going to measure the bolt holes in the radiator then look for a plastic shrowd. If you are going for looks, Summet or Jegs can probably get you a stainless one. Don't forget to buy a fan after you buy the shrowd...you'd hate to go through all that trouble and the fan be too big for the fan hole.
Old Jun 2, 2005 | 07:50 AM
8NRay's Avatar
8NRay
For my '71 F100 w/360 engine, I got the shroud from LMC and the fan clutch and fan blade from my local Car Quest parts store.
Old Jun 2, 2005 | 09:47 AM
ramtoo's Avatar
ramtoo
8NRay what did the shroud from LMC set you back? Does anyone know if its still one size fits all from 67 to 72?
