starter issues
Old Aug 10, 2011 | 09:07 PM
puck1980's Avatar
puck1980
starter issues
I have a 74 f350 with a 460 engine and a 4 speed manual tran (not the original engine but i think the tranny is) i replaced 2 starters in a week as they both had the bendix teeth ground off ! I checked the flywheel and all teeth look perfect ! Both times the starter worked great on first couple starts but then the grinding starts wich i assume is the bindix staying ingaged. I have tried using the shim plate but that didnt help? Desperate for a resolution! thanks Don
Old Aug 10, 2011 | 09:25 PM
mark a.'s Avatar
mark a.
Wondering what led up to this ? Did the origional one go bad then the replacements teeth ground off ? There are 2 different tooth counts for the starter Bendix. I (think) one is 9 the other 11.
Old Aug 10, 2011 | 10:52 PM
puck1980's Avatar
puck1980
starter
Yes, the starter went out and i have replaced it with 2 replacements but i never kept the first one it was sent for core. So i dont know what the tooth count was.
Old Aug 10, 2011 | 10:59 PM
ford390gashog's Avatar
ford390gashog
Being that the 460 was never offered with a 4spd who knows what teeth count it should have !You may want to understand this 1973-1979 Ford Truck 460 V-8 Swap
Dalton12316
Mar 13, 2017 05:06 AM
jab55
May 4, 2010 10:55 PM
78250crewcab4x4
Jan 22, 2010 10:28 AM
monte54
Jan 1, 2006 08:42 AM
