help
Old Aug 14, 2011 | 05:22 PM
a711112a's Avatar
a711112a
up date..... Today I disconnected the batteries then pulled the pcm and looked it over. plugged every thing back in. Then I puled the fcim took it apart and looked for cracked solder joints found none. Put it back together reconnected the batteries....... Now it starts fine idles fine, but when I step on the throttle it cuts out and dies. No check engion light just the battery light. Also just pulled 2 codes p2614 and p2617. I was thinking the TPS but ??????
Old Aug 14, 2011 | 06:41 PM
BLADE35's Avatar
BLADE35
I think 2614 and 2617 codes are just from the engine stall
I dont beleive that those two sensors both went out together plus didnt you just replace these
what was the ICP psi and IPR%
you need to check your batterys and alternator volkt
start checking the grounds to
Old Aug 15, 2011 | 02:03 PM
a711112a's Avatar
a711112a
final up date..... It is fixed Turned out problem was wire chaffing on the harness right below the turbo inlet pipe........... Thank you all who chimed in to help
TylerGarret
2004 - 2008 F150
Jan 3, 2010 10:55 AM
striker_wvu
Apr 16, 2008 07:34 PM
djctoll
1983 - 2012 Ranger & B-Series
Sep 14, 2005 07:52 PM
danielharr79
May 14, 2005 11:03 PM
95f1504x4
Oct 8, 2002 09:25 PM
