Tranny on it's last leg?
OK, so I just got finished flushing my tranny and when I dropped the pan it had what I would consider to be quite a bit of "fuzz" on the magnet. No flakes or anything large, just fine particles.
When I bought the truck on halloween last year, the carfax had something like 28 service reports dealing with regular maintenance. I don't remember however if it said anything about the tranny. The service records were from a dealer and were on schedule until the 80K mile mark.
The tranny fluid was dark but didn't smell scorched. I'm thinking that the fluid may not have been changed in the last 80K or so. If I had to guess I would say there was 2 or 3 tablespoons of fuzz. It had an OEM gasket and filter. The only problem I've been having with it is when I shift from park into drive, it didn't slip, it just wouldn't "engage". With the fresh fluid that seems to have gone away.
So my question is... Am I worrying over nothing or am I about to buy a new 4R100 HD?
I would start saving. Fresh fluid and filter will "refresh" your tranny, but if you have a chia pet instead of a magnet then you may want to start setting aside some $$.
Pay close attention to how your tranny acts now. Shift firmness, timing....RPMs when in gear...fuel mileage. Alot of that can tell you if it is starting to slip.
When I left for work tonight (first time driving more than 3 miles since changing fluid/filter) I noticed a few things had changed. My hesitation of going into gear was gone, my (very slight) shudder was gone, and it shifts smoother in all gears. I had assumed the shudder was the slip joint in the drive shaft needing a good lube job.
After seeing the tranny fluid I now know how much I have ahead of me getting my "new" truck up to par. I never considered my wallet to be too thick, but I'm pretty sure I'm gonna be thinning it down further with several preventive maintenance projects. I guess I just caught a strong case of PMS!
Rodney, two things.
Start putting back some money and start looking for someone in Knoxville that can get Ford parts at cost. You should have time for both and it makes the decision to get the OEM a lot better.
I got mine for cost plus tax. $3K , but I did the install. Runs good.
I need to get a DP F5 to help the shifting. I also have AE on the short list so that I can do a baseline slippage (which there shouldn't be) to watch the history.
If I figure out how to use the AE software, I would be happy to hook it up for you also. It would let you periodically (I am told) take a new ready and see if the slippage is getting worse.
My tranny went out all at once. It was slipping a little, but it just let go.
I don't know if my OEM HD is "less better" than the JW or BTS, but I don't think that anyone could tell the difference without swapping them around in the same truck to feel the difference.
Rodney, two things.
I should've just married him!
If you plan no mods and don't do a lot of stop and go towing, you can probably get away with the cheaper rebuild. Those are good for 3 yrs so if you are going to sell it by then, I would get that. OTOH, if you are fixing it to sell, get the cheapest thing by Jasper, Aamco, etc, etc. New owner won't pay you more for it anyways.
JW and BTS are the only ones I know of that will honor a warranty IN SPITE OF the mods. Remember, anyone can say anything before money changes hands. After it changes hands, well......
I went with BTS because I knew I would break the trans sooner or later and usually outside warranty. BTS has a reputation of fixing it AFTER the 2 yr warranty is up for FREE. You pay shipping.
