bset guess here is going to be a cut o-ring on a dummy plug
That's what I was getting from all the reading I have been doing but the oil filter draining caught my attention. Like to rule that out before jumping into the dummy plugs.
the other possible issue is a failed pump shaft seal. being you have an 06 you still may be under 5/100 and warranty should apply if you are
Unfortunately not under warranty; however I did bring it to the dealer when it first started getting harder to start and still under warranty. They said they were unable to reproduce symptoms?
Not trying to hijack this thread. You've peaked my interest though as my driveway is sloped quite a bit. I've noticed start time seems to be different if I back in compared to pulling in.
use the search function. there is a 3-4 page thred on the subject. has vedio and all.
maybe someone nice will come along and post a link for you.
