IP timing
Old Aug 8, 2011 | 09:16 PM
anotherlawnguy's Avatar
anotherlawnguy
IP timing
I advanced the timing on the ip about 1/8 off the to lines. It does not smoke like it use to and runs better. My question is can i advance it a tad more? I do not have a temp gauge for exhaust.I just dont want to burn anything up. I use this truck daily for my landscaping business and it pulls a 18' trailer with tractors. It does blow black smoke on take offs and up hills but nothing at idle. Just trying to get a tad more power.
Not sure if i should start here but its a 87 f250 with 6.9. It has original injectors and IP. Should i change these first? would this help with power?
Thanks in advance
Old Aug 8, 2011 | 10:30 PM
91dirtydiesel's Avatar
91dirtydiesel
how many miles on fuel system?
Old Aug 8, 2011 | 10:33 PM
anotherlawnguy
193,000 miles
Old Aug 8, 2011 | 10:37 PM
91dirtydiesel
pump is probably getting tired, advancing it would make it feel better but, dont go to much, 1/8" at a time and mark your starting point so you can refer back to it if need be.
Old Aug 8, 2011 | 11:33 PM
hairyboxnoogle's Avatar
hairyboxnoogle
1/16th at a time might be safer, so you would be less likely to have to back it off after advancing. You want it to rattle just a hair more than normal when the cold advance is on.
Old Aug 9, 2011 | 12:54 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
its time for a set of injectors,rebuilt ip and then set the timing.it's about time for it's second refresh actually lol.
she's a money making truck.treat her right.you'll not only see increased performance,but fuel economy as well.
http://www.oilburners.net/wiki/tiki-...hp?articleId=7
Old Aug 9, 2011 | 06:47 AM
anotherlawnguy
Thanks everyone for the info. I have no complaints with the truck other then the dents..lol...How would i know if timing is to advanced? I really dont hear the rattle sound when cold timing is on. Just dont want to burn anything up. Thanks
The_Josh_Bear
Sep 14, 2013 11:04 PM
Brant Bowrifle
Oct 5, 2011 09:16 PM
KyleG
Oct 12, 2007 12:51 PM
trooperkelly
Jul 16, 2007 05:07 PM
seizure911
Apr 18, 2007 05:38 PM
