timing question
Old Jul 16, 2007 | 09:34 AM
trooperkelly's Avatar
trooperkelly
timing question
Just replaced i.p. and all injectors in my 94' turbo. It had bb injectors in it and replaced them with g code and a 5069 pump, milage was around 10 mpg.On setting the timing with cold advance on i set it with a pretty good power stroke rattle that mostly goes away after warm up.The problem is i am getting a little black smoke at idle and wonder if the timing is off a little and which way to turn the i.p. to advace or retard the timing.
Old Jul 16, 2007 | 12:10 PM
David85's Avatar
David85
Since you still have a slight rattle after warmup, I would try to retard it just a little bit. Other that idle, how does it run and drive?
My hunch is that the CDR valve may also need to be serviced. My truck was also throwing a little smoke at idle, and soaking the CDR in gas overnight was the fix.
Old Jul 16, 2007 | 12:57 PM
trooperkelly
runs and drives great,milage seems to have improved but will be sure at my next fill up. Which way do i turn the i.p. to adjust? As far as the cdr i cleaned it out about 5k ago but i'll do it again it can't hurt
Old Jul 16, 2007 | 05:07 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Top of the IP to the drivers side is retard.
Sounds like you are about where you want to be, maybe just a tiny bit more to the retard side.
charger6t9r
Sep 17, 2013 08:26 PM
JHoffman93
Sep 18, 2011 02:30 PM
Kendrick
General Diesel Discussion
Mar 16, 2011 06:22 PM
deceptichop
Feb 27, 2011 07:52 AM
iam me
Jan 3, 2010 09:37 PM
