Spring Perch relocation??
Old Aug 8, 2011 | 02:09 PM
tjdad62's Avatar
tjdad62
Hey guys,
I finally got my 9 inch rear end installed and all bolted up. I read in the How Tos link that the spring perches are already in the correct location and don't need to be moved. I used a 1970 F100 9 inch and after its installed, the pinion points upward slightly. I have read other articles pertaining to drive shaft phasing that the pinion and trans tailshafts need to be parallel to each other but the tailshaft needs to be a few inches higher so that the u-joints will work properly. Has anyone relocated their perches to bring the pinion parallel to the ground? I am thinking that as long as the driveshaft is not perfectly straight fromt he tailshaft to the pinion, then I will be ok. Am I offbase on this?
Old Aug 8, 2011 | 02:21 PM
Old F1's Avatar
Old F1
Isn’t the 1970 too wide for the monkey face? In ’65 when Ford went to the twin I-beam they increased the track width?
The trans output should be 3 degrees downward (built into the intake manifold, carb base level then the trans is 3 degrees down automatically) and the pinion yoke 3 degrees up. Side to side offset doesn’t matter.
Old Aug 8, 2011 | 02:42 PM
mtflat's Avatar
mtflat
No OldF1, the swap is good up thru 72. 73 is when they got wider - about 3" more.
I made the adjustment by using 5 deg caster wedges. I believe they now call them tapered shims. NAPA sells them in a variety of widths - 2" is just right for your app. Last ones I bought they showed only 4 deg as the max they carry.
That gets the pinion close to where it needs to go. It can be off a little and still work fine. As OldF1 said the trans is down about 3 so the pinion needs to point up 1-5. Your mileage may vary.
Old Aug 8, 2011 | 08:08 PM
52 panel's Avatar
52 panel
Do you know if the pre-73 9 inch will fit into the f-1 Panel?
Old Aug 8, 2011 | 09:19 PM
51PanelMan's Avatar
51PanelMan
Any 57-72 F100 9" rear end will fit. From what I remember, 57-68 doesn't require any mods to the spring perches. 69-72 does.
filthy6
Mar 18, 2016 12:35 PM
buff64
Apr 28, 2013 11:32 PM
mexicanmjp
Apr 29, 2006 09:46 PM
terekpau
Jul 23, 2003 07:50 AM
fatfenders
Apr 1, 2003 08:25 AM
