idle and speedo problem need help
Old Aug 7, 2011 | 07:58 PM
95 f350's Avatar
95 f350
95 f350 460 surges and dies when going in reveres and drive also speedo bounces all over when driving and pickup bucks every once and a while going down highway dont no if connected but all started at same time. already changed wheel speed in rear end and tried to pull codes but nothing please help
Old Aug 8, 2011 | 08:59 AM
subford's Avatar
subford
Sounds like a bad PSOM, bad wiring or rear end.
Need to look a the signal from the VSS to the PSOM with a scope at the hood plug.
Might try unplugging the RABS module and see what happens.
Old Aug 8, 2011 | 07:23 PM
95 f350's Avatar
95 f350
thanks ill try that
Old Aug 8, 2011 | 08:00 PM
subford's Avatar
subford
Was your RABS light in the cluster coming on?
Old Aug 8, 2011 | 09:36 PM
95 f350's Avatar
95 f350
no lights at all. tried to pull codes but nothing showed only thing i found was 02 was rich and also dont know what fuel pressure sould be but it was moving around alot
Old Aug 8, 2011 | 11:55 PM
subford's Avatar
subford
How are you reading fuel pressure?
If you are it should b3 around 32 PSI at idle and around 40 PSI at WOT.
Tyger95
26
May 18, 2014 07:12 PM
fishn
Aug 19, 2010 09:09 AM
mack9truck
Nov 4, 2007 06:43 PM
toproller
Oct 24, 2006 08:03 PM
akmud
1978 - 1996 Big Bronco
Jan 17, 2006 09:46 AM
