Tolerance on head gasket surface
Old Dec 4, 2010 | 05:00 PM
ehgeeray's Avatar
ehgeeray
Is +/- 0.005 acceptable for stock gaskets? My heads pass +/- 0.005 but fail +/-0.002
Old Dec 4, 2010 | 06:05 PM
vloney's Avatar
vloney
FMC says that anything more than .004........scrap the heads.
Old Dec 4, 2010 | 06:35 PM
ehgeeray's Avatar
ehgeeray
I have more details.... I'm out 0.003 in one place. I had my black onyx gaskets blow at in the one place were if was out 0.003. Do you think I will be Ok with stock gaskets?
Old Dec 4, 2010 | 07:02 PM
ljutic ss's Avatar
ljutic ss
Why take the chance of gasket failure again if it can be avoided. If your head that blew the gasket was OK when you put the Onyx gaskets and ARP studs on failed, then it's not saying too much for the studs.
Old Dec 4, 2010 | 07:14 PM
ehgeeray's Avatar
ehgeeray
the thing is i don't know if I can machine any more off because I bought a reconditioned set. they were suppose to be decked when I received them I did check to verify flatness plus it would have been very hard to find this small spot it is only ~1 inch wide between one cylinder and the closest coolant passage. How for I know if any more material can be machined off?
dizzyfingers03
1983 - 2012 Ranger & B-Series
23
Mar 24, 2015 07:34 PM
hooltech005
Feb 27, 2015 12:10 PM
BroncoBilt
1978 - 1996 Big Bronco
Jan 15, 2015 06:03 PM
recupirate
Apr 17, 2014 11:09 AM
adamsrancho
Jan 30, 2014 05:39 PM
