Front Passenger Inside Tread Feather
Old Sep 21, 2011 | 09:39 PM
GHeTTo JOe's Avatar
GHeTTo JOe
you are correct the joint side is twisted differently.
Old Sep 23, 2011 | 07:39 AM
mechelement's Avatar
mechelement
Thanks guys. I'm going to order the correct parts.
The weird thing is that I had new tires installed not too long ago. My wife took the truck in for this and I told them to perform a front alignment. The guy threw it on the alignment machine and everything was within spec. I had them grease the front end and check for any damaged joints and they said everything was tight, almost like new. I expected that because I rebuilt the axle, but did not replace the steering joints. I really expected them to say the steering joints were toast...
I've read on here somewhere, that tire shops can't truly align these trucks because of the camber sleeves. Is this truly the case? Would the camber sleeves be suspect for misalignment? Is Ford the only place that can perform a true alignment on these trucks?
I'm tempted to buy new leaf spring bushings and go for the gold all around, then have the thing fully aligned after. I'll probably regret this when the bolts start stripping, breaking or won't budge.
Domestic_Nuwbee
15
Jul 10, 2012 04:45 PM
Supercab
Mar 14, 2009 04:22 PM
wresleu
Aerostar
15
Jan 12, 2006 06:34 PM
stateteam
1997 - 2003 F150
Apr 21, 2005 12:12 AM
seymour
Jun 11, 2002 10:58 AM
