stuck on a pushrod
Old Aug 29, 2011 | 03:51 AM
xlt4wd90's Avatar
xlt4wd90
Yes, the lifter should push the rod up after you push it down. When it's pressurized with oil, it will give a lot less; it has to push open the valve. With the correct length rod, as you bolt down the rocker arm, the gap should be completely taken up about 3/4 turn before the bolt is completely torqued down. When the bolt is torqued down, the parts should have some pressure on them.
I guess it's too late to measure the length of the Chevy valve stem, to compare to the stock Ford version? If the difference is too much, it might be necessary to change the rocker position to get the tips to line up, and then get the right length push rods to match. But that's going to be difficult with non-adjustable studs.
Old Aug 29, 2011 | 05:00 AM
corytcline's Avatar
corytcline
I have been told that the valves may have been cut to size when installed in the heads. I don't know if that was done or not. I know everything on this motor has been a pain in the rear. It has let me know that I am no engine builder.
Should I just tear it down to the lifters, and make sure they are all pumped up and then start over? Some of them seem pumped up but others don't. Is there a place to get push rods at any length? On Jeggs web site for a ford 302 all I can find are the two sizes that I have already mentioned. Because thats all I have found I assume it has to be one of those sizes.
Thanks for all the help. Sorry if I'm a little slow this is my first build. I just don't want to be the guy that starts his motor the first time and everything breaks from not being put together right.
Old Aug 29, 2011 | 11:24 PM
xlt4wd90's Avatar
xlt4wd90
Like I said, when you're checking the cold lash, you turn down the bolt until all the gap is taken up, and then you should be able to turn another 3/4 to 1 turn to torque it down. Any more, and the pushrods are probably too long, any less, they're probably a little too short. The lifters don't really need to be pumped up for that check; you will be pushing against their internal springs, and that should be fine.
I'm sorry that I'm only guessing here, based on my own experiences. I wish I could be more helpful.
Old Aug 30, 2011 | 06:03 AM
ilovemy60ford's Avatar
ilovemy60ford
Where are you at in OK?
Old Aug 30, 2011 | 06:16 PM
corytcline's Avatar
corytcline
Mcloud, Oklahoma
Old Aug 30, 2011 | 06:29 PM
corytcline's Avatar
corytcline
Had to swallow my pride. I caught a local engine builder in his garage last night. I stopped and asked him about my problem, turns out I have some kind of screw down rockers not non adjustable like I thought. He also gave me instructions on how to use the checker and exactly how many turns past zero lash. Supposed to take the checker back today so he can measure for me, I think he is gonna order the rods for me too.
I have know about this guy for some time, he is also the mayor of our little town. We have a chilli cook off here every year and he gives away one of his motors to the lucky winner of a drawing where you purchase the tickets to be drawn.
Just want to give thanks to him I'm not sure if he is a member of this forum or not but to John Barrett of John Barrett's Hot Rod Engines thanks for the help.
To all the guys on this forum thanks for your help as well, you may not think so but you guys helped alot.
Old Sep 10, 2011 | 10:53 PM
corytcline's Avatar
corytcline
got the rods measured, they ended up being 6.950. Just got them in the motor today. That was the last major issue with finishing the motor. Now got to get the ignition wired, tranny lines ran, radiator installed ect. ect.
If anyone knows how to upload a video on here please let me know, I would like to post a video of the start up. Even if it goes bad I will still post it.
There are a few holes in the block that I'm not sure if they are supposed to be sealed off or not. Will get some pics of them and post asap.
Old Sep 11, 2011 | 02:00 AM
xlt4wd90's Avatar
xlt4wd90
If you can't figure out how to post videos here (I never did), post them on youtube and post a link here.
Old Sep 12, 2011 | 06:32 PM
corytcline's Avatar
corytcline
I will post a link then.
spikinfool05
Feb 17, 2014 08:22 AM
400944
Oct 6, 2009 09:13 AM
bigdan1979f-250
Oct 19, 2006 10:53 AM
Hepper
Nov 27, 2003 02:31 AM
grif95
Feb 3, 2003 09:46 AM
